  3. pspice error(Subcircuit LOWONSWITCH used by X_U8.X1 is undefined...
  • Views 3416
pspice error(Subcircuit LOWONSWITCH used by X_U8.X1 is undefined)
Jacky007
Jacky007 over 13 years ago
sir:
   I use the orcad10.5,and I construct a project in the capture cis. In the schematic, I use a device adg1211. I download the psice model of adg1211 from website of anolay.com, and I build the .lib and .olb file by myself. I surely add the .lib file path to the project and add it as the global library, but the pspiceA/D report errors as follow:
ERROR -- Subcircuit LOWONSWITCH used by X_U8.X1 is undefined
ERROR -- Subcircuit LOWONSWITCH used by X_U8.X2 is undefined
ERROR -- Subcircuit LOWONSWITCH used by X_U8.X3 is undefined
ERROR -- Subcircuit LOWONSWITCH used by X_U8.X4 is undefined
U8 is the device of adg1211 i use. Besides, I also confront the similiar error of other device model. what is the possible reason for these debugs??
thank you in advance.best wishes!
Jacky
2012-01-13
  • oldmouldy
    oldmouldy over 13 years ago
    LOWONSWITCH is part of the ADG1211 model, check that you have correctly downloaded the model text from the web site, save the LIB file from the model editor before exporting the Capture parts. Ensure that your LIB file for the ADG1211 has this entry definition:
    .SUBCKT LOWONSWITCH  101 102 103 104 105 106
  • Jacky007
     oldmouldy:
     The .lib file has the definition:
    .SUBCKT ADG1211 1 2 3 4 5 6 7 8 9 10 11 13 14 15 16
    * Logic Low On Switch
    * Connections
    *      101 = S
    *      102 = D
    *      103 = VIN
    *      104 = VDD
    *      105 = GND
    *      106 = VSS
    but it do not contain the definition:
    Is it right?
    Thank you......
    jacky
    2012-01-14
  • Jacky007
     sir:
         I surely download the correct model of ADG1211 from the website, and save lib file from the model editor before exporting the capture parts. In the lib file, there is not the definition:
     but it contain the definition:
    Is that is OK?
    jacky
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    This LOWONSWITCH model is included in Model definition available at Analog devices site. I have pasted the same below for your reference. You need to include complete model of ADG1211, that model and all models referred by it.
    Once simple way could be save the complete ADG1211.CIR file  (http://www.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html?cir=adg1211.cir)as .lib file and include that in simulation profile.
    Hope this helps.
    * Connections
    *      101 = S
    *      102 = D
    *      103 = VIN
    *      104 = VDD
    *      105 = GND
    *      106 = VSS
    x1 103 104 105 107 NOTGATE
    X2 107 108 104 106 105 VSENSE
    X3 108 105 109 ENABLEDELAY
    X4 101 102 109 104 105 106 SWITCH
    *MODELS USED
    .ENDS
  • Square
    Square over 11 years ago
    I have encountered the same error, I found all these model shares a common character, which is containing multiple subcircuits. When I tried to import them with the model editor, the editor can only recognize the very first subcircuit. After tried to unname the .cir to .lib and added to global library, it works now.
