  3. Expedition to Allegro conversion
  • Subscribers 166
  • Views 19407
Bala R
Bala R over 13 years ago
pls  let me know  the possiblities and steps in the conversion of PCB files from Expedtion to Allegro.
also let me know  the  issues  in doing so. ?
Bala R
  • steve
    steve over 13 years ago
    I'm pretty sure you can export a Pads asc from Expedition which you can import directly into Allegro from File - Import - CAD Translators - Pads.
  • Bala R
    Thanks Steve.
    I go the ASCII file from Mentor . When i try to import in Allegro 16.3  it's  gives eror and didn't import.
    AScii file syntax
    // BOARD STATION Ascii Geoms
    // Created by the IGES Translator Version v8.13_1.1 (BSXE2007) Wed Mar 19 09:43:02 EDT 2008
    // Date: Fri Mar 02 16:38:55 201
    Allegro error file
    *****  Starting Translation using version: v16-3-85CP_10/31/2011
    *****  Reading Input Mentor Files
         Geometries ASCII File: E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/iges_geoms.ascii
         Tech File:             E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/tech.tech_1604
         Nets File:             E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/nets.nets_233
         Components File:       E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/comps.comps_155
         Pins File:             E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/pins.pins_228
         Traces File:           E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/traces.traces_31
         Testpoints File:       E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/testpoints.testpoints_227
    ERROR: Component instance C158 references geometry 1005_c.
    Geometry not found.
    ERROR: Unable to proceed with translation.
    Parser problem.
    Error reading file E:/Project/Intel/XMM2210/Inputs/Others/LnT_20120827/xmm2250_rev2_20120827_1530/pcb/comps.comps_155
    Line Number: 11,  Token: 4
    Line: C158  GRM1555C1E270JA01D  cap  1005_c  7390000 15030000 1 0   -
    Error: Unable to parse input files
    Import Failed to Complete
    Pls note: I am using Allegro16.5 with hotfix So45
    Pls guide .
    Rgds
    bala R
  • steve
    Based on the screenshots you don't have a Mentor Expedition file you have a Mentor Boardstation file set. You can import this directly into Allegro 16.5 (you used to need an Allegro XL license to do this in 16.3). Use the File - Import - CAD Translators - Mentor. You need all the individual files (tech, geoms, nets, components etc).
  • Robert Finley
    Robert Finley over 7 years ago in reply to steve
    I think that went away after 16.3.
    I had Allegro-L 16.3, so I got a TBL license for a year using Orcad Professional 16.5 (before I bought an upgrade to PA-3100.)
  • Robert Finley
    Robert Finley over 7 years ago in reply to Robert Finley
    Never mind.  I just realized what you meant.  The Boardstation translation is also an Allegro-only license feature.
