  3. how to simulate time varying capacitance in Orcad ?
  • Replies 9
  • Subscribers 163
  • Views 21807
reddytinku
reddytinku over 13 years ago
 Hi
I have a circuit which has piece-wise time varying period capacitance- how to simulate this type of circuit in OrCAD?
Thank You
  • oldmouldy
    oldmouldy over 13 years ago
    Use a Voltage controlled Capacitor, VC_CAP, and drive it with a VPWL.
  • reddytinku
     hi thanks for the reply
    i looked in to VC_CAP and VPWL. I have one more doubt, VPWL has input for only 8 time instances , how to increase these and howto make it as a periodic source ? what wil be the VPWL value after T8 th time ?
    http://postimage.org/image/8nwx1k3vf/
    Thank You
  • oldmouldy
    VPWL uses linear interpolation between the specified points, the "T8" value will remain till the end of the simulation,. If you need more points, use a VPWL_FILE source, this takes time / value tab demilited pairs from a file. There probably is some limit to the number of points but it must be large. Take care with manually edited data that time remains "monotonic", always going forwards, the simulator is going to baulk at trying to reverse time! You can get an idea of the required format by exporting results from the Probe window, select / display a single waveform in the Probe window, from the menu, Edit>Copy, open a text editor and Edit>Paste into the text editor, the text values for the points in the waveform will be pasted as text.
  • reddytinku
    got the concept. can we enter the time and voltage values in a simple text document or do we need to use any text editor ? how to upload this file to the VPWL_FILE source ? I tried through property editor of it, bt couldnt able to do it
    And my Orcad doesnt has Spice_elem library(which has VAR_CAP) so I downloaded the library and added to the Orcad capture, so when I started to run the circuit I am getting an  error  ''ERROR(ORPSIM-15108): Subcircuit AWBVC_CAP used by X_U1 is undefined '', how to over come this ?
    Thank you very much for your time, pease forgive me if I am troubling you.
  • oldmouldy
    Any editor that makes "plain" as apposed to "formatted" test will work, like Notepad, NOT Word. VPWL_FILE has a File property, this takes the full path and file name for the pwl file created, you can use .\pwlfile.txt to use a file called pwlfile.txt in the current directory.
    It sounds like you have the graphical library, OLB, for the spice_elem, you need the simulation library, LIB, and then add it to the Simulation Profile libraries so that the simualtor can find it.
