  3. Want to change D2PAK footprint with TO263-3 on Orcad/Allegro...
  • Replies 8
  • Views 6219
Want to change D2PAK footprint with TO263-3 on Orcad/Allegro PCB Editor
AamirZ
AamirZ over 13 years ago
I have a PCB *.BRD file. No schematic no netlist. On board 03 D2PAK footprint placed U28, U29, U30. I want to replace a only U29 footprint D2PAK with To263-3. Any body know the procedure to replace the footprint without schematic and netlist.
  • Bonz
    Bonz over 13 years ago
    Check the other thread you posted in...
  • Mstrghettorigg
    Mstrghettorigg over 13 years ago
    You could probably:
    1. Create new footprint
    2. Export netlist from existing board
    3. Edit netlist so that symbol/device name matches your new part for U29
    4. Correct netlist so the connections matches new part
    5. Import that netlist
    6. Place that symbol
  • AamirZ
    Thanks for reply. I export netlist change the required changes import the netlist through File>Import>Logic>Others but it shows many errors and nothing happen
  • AamirZ
    Can you describe the process in detail
  • Mstrghettorigg
    You probably need to export the library files from the board since you probably don't have the device files.
    File/export/Libraries
    Export to path you are set up to.
