I am getting license error while running cadence . When I am running licence with lmgrd it gives following error
[sabyasachi@jupiter ~]$ lmgrd [sabyasachi@jupiter ~]$ 20:15:59 (lmgrd) ----------------------------------------------- 20:15:59 (lmgrd) Please Note: 20:15:59 (lmgrd) 20:15:59 (lmgrd) This log is intended for debug purposes only. 20:15:59 (lmgrd) In order to capture accurate license 20:15:59 (lmgrd) usage data into an organized repository, 20:15:59 (lmgrd) please enable report logging. Use Macrovision's 20:15:59 (lmgrd) software license administration solution, 20:15:59 (lmgrd) FLEXnet Manager, to readily gain visibility 20:15:59 (lmgrd) into license usage data and to create 20:15:59 (lmgrd) insightful reports on critical information like 20:15:59 (lmgrd) license availability and usage. FLEXnet Manager 20:15:59 (lmgrd) can be fully automated to run these reports on 20:15:59 (lmgrd) schedule and can be used to track license 20:15:59 (lmgrd) servers and usage across a heterogeneous 20:15:59 (lmgrd) network of servers including Windows NT, Linux 20:15:59 (lmgrd) and UNIX. Contact Macrovision at 20:15:59 (lmgrd) www.macrovision.com for more details on how to 20:15:59 (lmgrd) obtain an evaluation copy of FLEXnet Manager 20:15:59 (lmgrd) for your enterprise. 20:15:59 (lmgrd) 20:15:59 (lmgrd) ----------------------------------------------- 20:15:59 (lmgrd) 20:15:59 (lmgrd) 20:15:59 (lmgrd) FLEXnet Licensing (v10.8.6.0 build 54361 i86_re3) started on jupiter (linux) (4/6/2010) 20:15:59 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/ or Macrovision Corporation. All Rights Reserved. 20:15:59 (lmgrd) US Patents 5,390,297 and 5,671,412. 20:15:59 (lmgrd) World Wide Web: http://www.macrovision.com 20:15:59 (lmgrd) License file(s): /usr/local/flexlm/licenses/ license.dat 20:15:59 (lmgrd) lmgrd tcp-port 5280 20:15:59 (lmgrd) Starting vendor daemons ... 20:15:59 (cdslmd) FLEXnet Licensing version v10.8.6.0 build 54361 i86_re3 20:15:59 (lmgrd) Started cdslmd (internet tcp_port 56873 pid 21338) 20:15:59 (cdslmd) Cannot create lock file. Old lockfile exists. errno=13 (/var/tmp/lockcdslmd): Permission denied 20:15:59 (cdslmd) EXITING DUE TO SIGNAL 41 Exit reason 9 20:15:59 (lmgrd) cdslmd exited with status 41 (Exited because another server was running) 20:15:59 (lmgrd) MULTIPLE "cdslmd" license server systems running. 20:15:59 (lmgrd) Please kill, and run lmreread 20:15:59 (lmgrd) 20:15:59 (lmgrd) This error probably results from either: 20:15:59 (lmgrd) 1. Another copy of the license server manager (lmgrd) is running. 20:15:59 (lmgrd) 2. A prior license server manager (lmgrd) was killed with "kill -9" 20:15:59 (lmgrd) (which would leave the vendor daemon running). 20:15:59 (lmgrd) To correct this, do a "ps -ax | grep cdslmd" 20:15:59 (lmgrd) (or equivalent "ps" command) 20:15:59 (lmgrd) and kill the "cdslmd" process. 20:15:59 (lmgrd)
Please help to fix this problem .
Follow the instructions in the log file, looks like you have two vendor daemons running, FlexLM vendor daemons will not allow this. You may need to check the starting of the license manager processes to resolve the problem.
