HI,
My cadence was working first of all . Now while i am loading it. gives me following error.
fmdmt@fmdmt:/$ /home/fmdmt/eda/cadence/virtuoso/tools/dfII/bin/32bit/virtuoso: Symbol `_ZTVN8oaCommon9StringImpE' has different size in shared object, consider re-linking[1]+ Segmentation fault (core dumped) virtuoso
can any one help on this ?
Check to see if you have OA_HOME environment variable set. With later releases, this variable is known to cause problems and should be unset.
Tim
