• Home
  • Community
  • Blogs
  • The Design Chronicles
  • DAC 2016: Saving Design Time with an Electrically Aware…
The Design Chronicles Blogs
Christine Young
Christine Young
8 Aug 2016
Subscriptions
  • All Blog Categories
  • Breakfast Bytes
  • Cadence Academic Network
  • Cadence Support
  • Custom IC Design
  • カスタムIC/ミックスシグナル
  • 定制IC芯片设计
  • Digital Implementation
  • Functional Verification
  • IC Packaging and SiP Design
  • Life at Cadence
  • The India Circuit
  • Mixed-Signal Design
  • PCB Design
  • PCB設計/ICパッケージ設計
  • PCB、IC封装:设计与仿真分析
  • PCB解析/ICパッケージ解析
  • RF Design
  • RF /マイクロ波設計
  • Silicon Signoff
  • Spotlight Taiwan
  • Tensilica and Design IP
  • Whiteboard Wednesdays
  • Archive
    • Cadence on the Beat
    • Industry Insights
    • Logic Design
    • Low Power
DAC 2016: Saving Design Time with an Electrically Aware Design Flow
With a portfolio including dedicated automotive ICs, discrete and power transistors, MEMs and specialized imaging sensors, and digital ASICs, STMicroelectonics is a leading provider of smart driving and internet of things (IoT) technologies. On June 7, Pierluigi Daglio, analog verification manager at the company, took the stage at the Cadence Theater at the Design Automation Conference (DAC) to share how an electrically aware design flow can shorten the design cycle.
In the mid-80s, STMicroelectronics introduced its BCD technologies, integrating bipolar, CMOS, and DMOS into a single-process platform for power ICs. The technologies are widely used today, and include:
  • High-voltage BCD for lighting, motors, and electric cars
  • SOI BCD for full digital amplifiers, echography, and pico projectors
  • Advanced BCD for printers, airbags, automotive applications, and power supplies
  • High-voltage CMOS for bio-medical and advanced analog applications
 Pierluigi Daglio of STMicroelectonics
Designing these and other chips with a traditional design flow comes with limitations. It’s a serial process, for one, and the design must also accept tradeoffs, Daglio said. There are no notions of the electrical information inside the layout. In addition, he noted, LVS clean is a must in order to perform parasitic extraction.
Bringing into simulation electrically aware design after circuit/schematic design, on the other hand, allows you to find and fix problems early on. “You save a lot of time in your design phase,” Daglio said.
Electrically aware design enables these flows:
  • Simulation-driven electromigration analysis
  • Constraint-driven parasitic flow
  • Back annotation and simulation with physical effects
Earlier this month, STMicroelectronics announced that it is using Cadence’s next-generation Virtuoso platform to enhance layout design automation for its BCD SmartPower technologies. The platform includes an electrically aware design capability via the Virtuoso Layout Suite for Electrically Aware Design. At the top level, Daglio explained, the flow allows designers to set resistance constraints, perform point-to-point resistance calculation, and do electromigration (EM) checks with a custom approach. His team is working with Cadence to implement DC IR-drop constraints in the schematic. In addition, STMicroelectronics has updated its design kits to support the newest Virtuoso platform in production use.
At the cell level, the Virtuoso flow is useful for the in-design phase, providing features like EM analysis based on dynamic transistor-level simulation, point-to-point resistance calculation, RCC parasitic extraction, and schematic electrical constraints. “Electrically aware design prevents most of the EM issues in the layout generation phase, increasing the productivity of the designer and speeding up the whole IC verification process,” said Daglio.
He noted that while electrically aware design shouldn’t replace your signoff tool, it does help prevent large problems from cropping up at the end of the design cycle. And, he said, it is fairly easy to integrate into the flow.
Christine Young
Tags:
  • EAD |
  • DAC 2016 |
  • Design Chronicles |
  • electrically aware design |
  • STMicro |
  • dac53 |
  • Virtuoso Layout Suite |
Share Your Comment
Post (Login required)
