• Home
  • Community
  • Blogs
  • The Design Chronicles
  • Making Rigid-Flex PCB Design a Little Easier
The Design Chronicles Blogs
Christine Young
Christine Young
23 May 2016
Subscriptions
  • All Blog Categories
  • Breakfast Bytes
  • Cadence Academic Network
  • Cadence on the Beat
  • Cadence Support
  • Custom IC Design
  • 定制IC芯片设计
  • Digital Implementation
  • Functional Verification
  • IC Packaging and SiP Design
  • The India Circuit
  • Insights on Culture
  • Mixed-Signal Design
  • PCB Design
  • PCB、IC封装:设计与仿真分析
  • RF Design
  • Silicon Signoff
  • Spotlight Taiwan
  • Tensilica, Design, and Verification IP
  • Whiteboard Wednesdays
  • Archive
    • Industry Insights
    • Logic Design
    • Low Power
We now almost take for granted that computing power can be wrapped around our wrists or worn on a chain as a necklace. An array of wearable, mobile, military, and medical devices now rely on flex and rigid-flex PCBs to support the small form factor and light weight required. However, as flexible PCB fabrication technology has continued to mature, new PCB design and fabrication challenges have emerged.
Designers once integrated the flexible portion of their circuitry as a connector from one rigid board to another. But now that there are even more stringent area demands, designers are now placing components on the flexible circuit area. Ensuring that these designs are correct by construction and, thus, can be fabricated as expected calls for a variety of inter-layer checks of areas such as:
  • Stack-up mask layers
  • Coverlay to pad
  • Mask to pad
  • Precious metal to coverlay
  • And many others, while also accounting for various design considerations
Rigid-flex PCBs and new materialsRigid-flex PCB designs incorporate many new materials, which lead to new challenges to address.
Cadence has launched a new capability in both its Allegro 17.2-2016 and its OrCAD 17.2-2016 PCB design releases that automates inter-layer, in-design checks in rigid-flex PCBs. Using this capability, PCB designers can perform DRCs on various non-electrical flex layers, flagging errors early on and reducing iterations. Learn more about rigid-flex design challenges as well as this new rigid-flex design function in a new white paper, Automating Inter-Layer In-Design Checks in Rigid-Flex PCBs. And let us know what you think.
Christine Young
Tags:
  • flex design |
  • OrCAD |
  • PCB design |
  • flexible circuitry |
  • rigid flex design |
  • Allegro |
Share Your Comment
Post (Login required)
