  3. Procedure in Innovus common UI to generate scripts for ...
  • Subscribers 92
  • Views 254
Procedure in Innovus common UI to generate scripts for placement
nrk1
nrk1 14 days ago
In an older Innovus version (152), the following lines were executed before placement. pnrflow/ was generated in innovus using "writeFlowTemplate -directory pnrflow"
  • ./pnrflow/SCRIPTS/gen_flow.tcl all
  • make init
In the new common UI, "writeFlowTemplate" is replaced by "write_flow_template" according to the manual (foundation flows guide). When I run "write_flow_template -directory scripts" it generates the folder scripts/ and scripts/flow with the following content. How do I proceed? Web search points to a script "scripts/run_flow.tcl" as the equivalent of gen_flow.tcl, but no such script is generated in my case. Basically I need to equivalent of "gen_flow.tcl" and "make init" mentioned above.
scripts> 291: ls
design_config.template eco_config.template flow.yaml_template innovus_config.template setup.yaml_template
dist.py* flow/ flow_config.template metric_config.yaml
scripts> 292: ls flow
common_flows.tcl common_steps.tcl innovus_steps.tcl
Innovus version info:
Version: v21.18-s099_1, built Tue Jul 18 13:03:50 PDT 2023
Options: -stylus
Nagendra
  • NK202510274558
    NK202510274558 3 hours ago
    (I posted this on "Digital Implementation" forum a couple of weeks ago. I noticed that only a couple of posts in the last six months on that forum have replies. Hence trying my luck here.)
    • make init
    scripts> 291: ls
    Options: -stylus
    Nagendra
