• Home
  • Community
  • Forums
  • Functional Verification Shared Code
  • FEV ISSUE
Functional Verification Shared Code Forums
FEV ISSUE
Narayan2401
Narayan2401 10 months ago
I see unmapped points (not-mapped) on both golden and revised side. These are all ddr scan latches.
Eg-
*/latch_lo_gt_ctech_customlib_ddr_scan_latch[156]/o_reg in golden
*/latch_lo_gt_ctech_customlib_ddr_scan_latch[156]_clock_scan_latch_dt/sttb_$U4/udp1/U$1 in revised
There are many not-mapped similar to above one.
Below renaming rule doesn’t seem to work
ren rule r1 "_clock_scan_latch_dt" "\/o_reg" -rev
Could someone please help here?
  • Reply
  • Kasey00
    Kasey00 3 days ago
    He first might not be a robust solution because the delay of the buffers would vary across the PVT corners and RC corners. In the worst case, there might be a significant variation in the delays across corners and you might witness closure of timing in one corner, but violation in other https://vidmate.bet/ corner.
    • Up 0 Down
    • Reply
