• Home
  • Community
  • Forums
  • PCB Design
  • Create a new Constraint Group or Constraint Class ?
PCB Design Forums
Cailloux
Cailloux 9 months ago
When in Constraint Manager, Physical Domain, one can create a new Physical Constraint Class defining specific attributes for a custom rule set. One can then assing this new rule set to a set of nets. To do that it is instructed to create a new Net Class with menu Objects > Create > Net Class. Also on that same menu is available Net Group. Both options create a group that appear in the Constraint Manager Objects Name Column. I have triied both  options and cant really see the difference.
The Question: What is the difference between creating a Net Class and a Net Group ?  What are the implications ?
Thanks for your help.
  • Reply
  • mcatramb91
    mcatramb91 9 months ago
    The general differences between a Net Class and Net Group are:
    • A Net Class is group of nets specific to a particular domain (Physical, Spacing and Electrical)
    • A Net Group is a group of nets that common across all domains
    You could create a common Net Group then assign a Constraint Set to drive basic rules:
    • Net Group NG1 could have a Physical Constraint Set assigned in the Physical domain
    • Net Group NG1 could have a Spacing Constraint Set assigned in the Spacing domain
    • Net Group NG1 could have a Electrical Constraint Set assigned in the Electrical domain
    Implications?  Constraint Region Rules and Class to Class Rules cannot be assigned to Net Groups
    • Physical domain: You can specify Physical rules for a Physical Class inside and/or outside of a specific Constraint Region.
    • Spacing domain: You can specify Spacing Class to Class rules when different Spacing Classes come in contact with each other inside and/or outside of a specific Constraint Region.
    In addition, Net Classes are domain specific groups so if you wanted to have one larger group of nets to control Spacing rules and a sub-set of those nets to control Physical rules it can be easily done with Net Classes.
    Think of Net Groups as a higher level group of objects to organize interfaces.
    Hope this helps,
    Mike Catrambone
    • Up 0 Down
    • Reply
  • kevintaylor78
    kevintaylor78 1 month ago
    You can create a constraint class if you find a tutor on https://studyfy.com/tutoring for your classes. It is always a good option to learn from someone who knows how it works better than you.
    • Up 0 Down
    • Reply
  • rosie4
    rosie4 11 days ago in reply to kevintaylor78
    Definitely agree with you! And if you need help with your studies and you cannot write your thesis yourself, you can always turn to DissertationTeam and get help from people who really know how to do it. Help is always helpful.
    • Up 0 Down
    • Reply
