  2. Allegro X Capture CIS
  3. How to make Net Alias sort in schematic order instead of...
  • State Verified Answer
  • Replies 7
  • Subscribers 44
  • Views 3258
How to make Net Alias sort in schematic order instead of Ascending/descending inside Property Editor (disable automatic sort)?
waldo15b
waldo15b over 1 year ago
A few months ago I was working on a schematic project and I swear I was able to select a number of nets (aliases) and when I right clicked to open the Properties editor, the signals would be listed in the order they appear in the schematic reading from top to bottom. This allowed me to easily change names and do pin swaps using an excel spreadsheet.
Recently after the last few hotfixes, I have noticed that no matter what I do the nets will always be listed in alphabetical order, either ascending or descending, which complicates my ability to do the pin swaps and verify the new order is what I want, so I would like to disable this automatic sorting if possible. Even after I do the name changes, the signals will re-sort immediately into ascending/descending order making it virtually impossible for me to verify the new name assignments are correct unless I expand the information in the flat nets tab and check the Net ID association
Below is an example of how the net names show in the schematic and how they are automatically sorted in the Property editor. I would like the signals to be listed as shown in the schematic.
  • waldo15b
    0 waldo15b over 1 year ago in reply to rg13
    Thanks for looking into it.
  • JS202410091357
    0 JS202410091357 over 1 year ago in reply to waldo15b
    I had the same issue. Click on the y-coordinate column and sort that ascending. That will put your net names back into their original order.
