CommunityForums PCB Design Capture CIS I can't find the problem of this circuit - sbreak, wbreak...
  • Subscribers 16
  • Views 95
I can't find the problem of this circuit - sbreak, wbreak, ERROR(ORPSIM-16367): End of expression not seen
Nabong
Nabong 12 days ago
In order to simulate the equivalent circuit of a SiPM sensor,
I mad the following circuit referring to a paper.
However, the simulation does not work with the 'ERROR(ORPSIM-16367): End of expression not seen'.
I guess that there is an error in the switch part (Sbreak/BREAKOUT, W_ST/ANALOG)
I've tried several times to fix this, but I couldn't find it.
Can anyone please help?
  • Reply
  • AyushD
    0 AyushD 11 days ago
    this error generally comes if the >END statement is missing from the model definition though i believe W3 is a template based part.
    Also it looks like the looping wire connections between S1 and W3, are not connected. Can you space out S1 and W3 and then do the connections on wire but not on the pin ends.
    See if that helps
    • Up 0 Down
    • Reply
