Home
  • Products
  • Solutions
  • Support
  • Company
  • Products
  • Solutions
  • Support
  • Company
Community PCB Design Capture CIS Changing Several Offpages and Wire Aliases at once
  • State Verified Answer
  • Subscribers 23
  • Views 173
Firas Abd El Gani
Firas Abd El Gani 11 days ago
Since I need to make two design blocks for the same circuit, I want to differentiate between the blocks and change many signals name together at the same time.
I have signals that they are both of type "OffPage" and "Wire Alias", is there a way to change the name of each net globally, including all the appearances?
Instead of going to change one by one (like global change of parameter name in software).
  • Reply
  • AyushD
    +1 AyushD 11 days ago
    You can try Edit -> Global Replace option, that may help you
    • Up +1 Down
    • Reply
  • Firas Abd El Gani
    0 Firas Abd El Gani 10 days ago in reply to AyushD
    That's EXACTLY what I was looking for.
    Amazing!!
    Thank you,
    Firas
    • Up 0 Down
    • Reply
© 2023 Cadence Design Systems, Inc. All Rights Reserved.
