CommunityForums PCB Design Allegro PCB Editor and PCB SKILL How to download netlist with XNets from Orcad 17.4 to a...
  • State Verified Answer
  • Subscribers 139
  • Views 286
How to download netlist with XNets from Orcad 17.4 to a legacy layout?
TiffanyB
TiffanyB 12 days ago
I'm having problem download Orcad capture 17.4 netlist with XNets to a legacy Layout. It came up with an error below.
I'm not sure how to set up in Layout to be able to bring in XNets. Can someone help?
"Error: Schematic supports creating XNets for passive devices and for devices having XNET_PINS properties but the layout will create XNets only for devices having XNET_PINS properties. Change setting in Layout or Schematic, re-generate files, an re-run the flow."
  • Reply
  • steve
    +1 steve 12 days ago
    This should help Error: Schematic supports automatically creating XNets using DML Models but the Layout will create XNets only for devices having XNET_PINS properties. Change setting in Layout or Schematic, re-generate files, and re-run the flow (cadence.com)
    • Up -1 Down
    • Reply
  • Nakur5
    +1 Nakur5 11 days ago in reply to steve
    Try this maybe it will help you and solve your issue
    Error: Schematic supports automatically creating XNets using DML Models but the Layout will create XNets only for devices having XNET_PINS properties. Change setting in Layout or Schematic, re-generate files, and re-run the flow (cadence.com).
    • Up +1 Down
    • Reply
  • TiffanyB
    0 TiffanyB 11 days ago
    Thank you so much!
    • Up 0 Down
    • Reply
