Home
  • Products
  • Solutions
  • Support
  • Company
  • Products
  • Solutions
  • Support
  • Company
Community PCB Design Allegro PCB Editor and PCB SKILL How to fix the common SKILL error “fprintf/sprintf: format...
  • Views 130
How to fix the common SKILL error “fprintf/sprintf: format spec. incompatible with data”
PCBTech
PCBTech 11 days ago
For formatted output, SKILL provides the printf, fprintf, and sprintf standard C studio library routines. This error occurs if the data type of a variable does not match the format specifier.
There are two ways to fix this:
  1. Change the format specifier to match the data. In the example, change the format specifier from string (%s) to integer (%d):
              a=5
              printf("a is: %d:\n" a); instead of printf("a is: %s:\n" a)
  1. Change the data to match the format specifier:
              a=” a string”; instead of defining it as a number like in the previous example
To know about the common output specifiers, click here.
Team PCBTech
Cadence Design Systems
  • Reply
  • eDave
    eDave 11 days ago
    Another option, if you are unsure of the data type, is to use %L
    printf("%L\n", 1) returns 1
    printf("%L\n", 1.0) returns 1.0
    printf("%L\n", "a") returns "a"
    printf("%L\n", t)  returns t
    printf("%L\n", list(1 1.0 "a" t)) returns (1 1.0 "a" t)
    • Up +1 Down
    • Reply
  • HJerry
    HJerry 3 days ago
    Or,
    Check what type the data is using type(a) and use the correct format specifier.
    • Up 0 Down
    • Reply
© 2023 Cadence Design Systems, Inc. All Rights Reserved.
