Community Feedback, Suggestions, and Questions How do I find the license path?
Now I'm installing OrCAD 16.2.
  • The license path is going to be the port number at server name where the license manager is running. When the license manager was installed, it displayed the license path in one of the dialogs. IF you are running the license manager locally, chances are that the port number will be the default, 5280, and the server name will be the name of you machine, entered as 5280@<my_machine> no quotes required. IF the license manager is running remotely, you will need the name of the remote machine and which port number is in use, you sys admin should be able to provide this information, then add the port and server name as above.
  • Thank you for your detailed reply!
    I'll try it!
  • How do I change the licence server location after I have already installed the software? I can't seem to find how to do it and I get an error LMC-01902 when i try to startup the software. Thanks.
CDNS Forum Thread CSS JS
CDNS - Fix Layout
