Hi everyone,
I am facing a problem with the QRC check from a couple of days. I am trying to run QRC check by using Assura. I am using xu035 technology by xfab. DRC and LVS (Assura) run successfully and there is neither any error nor any warning. But when I try to run the QRC I receives the following error
_________________________________________________________________________________________________________________
Techgen -trans results will be written to directory: /home/msaif/xfab_xu035/AssuraLVS/inverter_cell_LVSERROR (CAPGEN-41222): No -p2lvs file '/cad/cds03/Cadence_Libraries/XFAB_TECH/XU035/cadence/xu035/Assura/XU035_4110/QRC-Typ/_p2lvsfile' (or '_p2lvsfile') can be found in technology directory. Need to have a p2lvs file ready and redo Techgen -trans initialization run in the techdir.INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance. /cad/cds03/Cadence_Tools/EXT81_2010/tools/extraction/bin/32bit//capgen -techdir /cad/cds03/Cadence_Libraries/XFAB_TECH/XU035/cadence/xu035/Assura/XU035_4110/QRC-Typ -lvs /home/msaif/xfab_xu035/AssuraLVS/inverter_cell_LVS.xcn -p2lvs /cad/cds03/Cadence_Libraries/XFAB_TECH/XU035/cadence/xu035/Assura/XU035_4110/QRC-Typ/qrcTechFile -sw3d -encrypt -p poly1,thickox_gate,gate_5Vox -dsub ndiff,pdiff,pwtrm,nwtrm,bkgnd -mos_diff_ap_nw -length_units meters -cap_unit 1.0 -cap_ground_layer bkgnd -blocking gatePoly,fox,gate_5Vox,poly1 -blocking d_cswt:0.1,fox,poly1,met1,met2 /home/msaif/xfab_xu035/AssuraLVS/inverter_cell_LVSForking: /cad/cds03/Cadence_Tools/EXT81_2010/tools/extraction/bin/32bit//capgen -techdir /cad/cds03/Cadence_Libraries/XFAB_TECH/XU035/cadence/xu035/Assura/XU035_4110/QRC-Typ -lvs /home/msaif/xfab_xu035/AssuraLVS/inverter_cell_LVS.xcn -p2lvs /cad/cds03/Cadence_Libraries/XFAB_TECH/XU035/cadence/xu035/Assura/XU035_4110/QRC-Typ/qrcTechFile -sw3d -encrypt -p poly1,thickox_gate,gate_5Vox -dsub ndiff,pdiff,pwtrm,nwtrm,bkgnd -mos_diff_ap_nw -length_units meters -cap_unit 1.0 -cap_ground_layer bkgnd -blocking gatePoly,fox,gate_5Vox,poly1 -blocking d_cswt:0.1,fox,poly1,met1,met2 /home/msaif/xfab_xu035/AssuraLVS/inverter_cell_LVSERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100INFO (LBRCXM-709): ***** QRC terminated abnormally *****
__________________________________________________________________________________________________________________
Please have a look on above error and suggest me how to resolve. Thanks for your time :)
