i am unable to get expected output for forward converter circuit of attached doc, becoz of transformer modeling(2 primaries and 1secodary) can anyone help me to model the transfomer.
I tried to create model from pspice modelling app available in latest release but iam not getting output,thank you in advance.
It could be the transformer model but I don't think that is the issue. I get about 15V "steady state" output with a Kbreak as the core, I dropped the filter capacitor value to uF, rather than mF to speed up the simulation getting to a stable output. (If you use mF I estimate the some secins of simulation run time will be required, rather than mS) Can you archive the project, File>Archive Project, create a single ZIP of the project and post the resulting file so that the actual data can be checked?
Thank you for reply , i have attached the project which i simulated .
can you provide the circuit snapshot for which you are getting the output of 15v as a reference for me.
This seems OK with standard components, I suggest that you check you transformer parameters. See attached.
Thank you.
hello ,
Can i attach the values which are given in the txt file to Kbreak & inductor components in the previous ckt,
which you have given as reference to me ?
thanks in Advance
