Hi Every one,
I get following error when I run PSS + pnoise simulation with ADEL-> setup->High performance simulation -> APS . Can any one help me
in this case.
Log file shows the following
Warning from spectre during circuit read-in. WARNING (SFE-2654): VerilogA module `respoly_va' override primitive/(verilogA module) `respoly_va'. WARNING (SFE-2654): VerilogA module `respoly_va' override primitive/(verilogA module) `respoly_va'.Warning from spectre in `n_12_llrvtrf', during circuit read-in. WARNING (SFE-2946): "/home/shravan/PDK/IC616_PDK_65nm/G-9FD-LOGIC_MIXED_MODE65N-LL_LOW_K_UMK65FDKLLC00000OA-FDK-Ver.B11_PB/UMK65FDKLLC00000OA_B11_DESIGNKIT/UMK65FDKLLC00000OA_B11/umc65ll/../Models/Spectre/./L65LL_RVT12_V101_RF.mdl.scs" 118: `n_12_llrvtrf': Parameter `w' redefines parameter of same name defined at higher level. Local parameter value will be used.Opening directory input.ahdlSimDB/ (775)Opening directory input.ahdlSimDB//12782_Models_Spectre_._._Rde65.va.Rde_n_12_llrvtrf.ahdlcmi/ (775)Opening directory input.ahdlSimDB//12782_Models_Spectre_._._Rde65.va.Rde_n_12_llrvtrf.ahdlcmi/Linux-64/ (775)Compiling ahdlcmi module library.Warning from spectre during AHDL read-in. WARNING (VACOMP-2397): Compilation failed when using pipe build. Bytecode flow will be used for encrypted VerilogA, and normal file compilation will be used for unencrypted VerilogA.Compiling ahdlcmi module library.Error found by spectre during AHDL read-in. ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//12782_Models_Spectre_._._Rde65.va.Rde_n_12_llrvtrf.ahdlcmi/Linux-64/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. Otherwise, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem. ERROR (SFE-91): Error when elaborating the instance Rde_n_12_llrvtrf. Simulation should be terminated.Warning from spectre during hierarchy flattening. WARNING (SFE-30): "input.scs" 67: M0: `mf' is not a valid parameter for an instance of `n_12_llrvtrf'. Ignored. WARNING (SFE-30): "input.scs" 67: M0: `mis_flag' is not a valid parameter for an instance of `n_12_llrvtrf'. Ignored.
Thanks and Regards
Shravan
