Community Feedback, Suggestions, and Questions Transient response of moscap
am currently working on a design of  PSK backscaterring modulator block for Passive RFID Transponder .  Currently  , I am designing based on the paper titled  "An ultra low-voltage low power PSK backscatter
modulator for passive UHF RFID tags compatible with C1 G2 EPC standard protocol ". Maryam Gharaei Jomehei • Samad Sheikhaei  in Analog Integrated Circuits and Signal Processing · September 2013
I should measure the variation of capacitance of moscap.  I have simulated the CV characteristics, however what  I require is the transient response of the change in capcaitance of moscap , similar to the attachment included below.
I would like to know if there is a method to do the same.
Any suggestions would be grateful.
Thank You,
CDNS Forum Thread CSS JS
CDNS - Fix Layout
