  3. ENTECHMACH: Multidisciplinary Design Optimization of a Multi…
AnneMarie S
AnneMarie S
ENTECHMACH: Multidisciplinary Design Optimization of a Multi-Stage Centrifugal Compressor
15 Feb 2019 • 4 minute read
Authors: Vladimir Neverov, Ivan Cheglakov, Specialists on compressor machines, Aleksandr Liubimov, Head of Advanced Development and Design Department, ENTECHMACH, Russia.
Research-and-production Company «ENTECHMACH», located in Saint Petersburg, Russia, has been operating in the power engineering area for more than 25 years. Its main activities are the design and production of centrifugal and axial compressors, steam turbines, multipliers, heat exchangers with air, and water cooling systems.
For two years now, the company has been using the OMNIS/Turbo package for the flow simulation and optimization of stationary industrial centrifugal compressors and for research engineering. One of those developments concerns the modernization project of a three-stage air centrifugal compressor in catalytic cracking technology.
Problem Analysis
The existing compressor suffered a number of drawbacks: low reliability of the axi-radial impellers as their covering discs were causing large stress concentration zones, failing stators due to unsuitable material choices, and a number of performance issues. The performance and discharge pressure were insufficient, the surge margin was too low, and the power consumption too high.
As a first step, we used NUMECA’s OMNIS/Turbo solver to accurately calculate a complete compressor performance map of the compressor. The result allowed us to clearly identify the main causes of these efficiency losses and low surge margins. Conclusion: The modernized compressor would need a complete replacement of the rotor and stator elements in the compressor case, bearings, and lubrication oil system.
Optimization
It was decided to design the new compressor with semi-opened axi-radial impellers, as they create two times less stress compared to the closed axi-radial version with covering discs.
To make sure the newly developed impellers meet the highest possible levels of efficiency, pressure ratio and surge margin, all flow path elements were optimized with NUMECA’s FINE/Design3D solver, including the impellers, the vane diffusers, and the return channels for several operating conditions.
With the use of the NLH method, the influence of the inlet chamber and 360° inlet guide vanes on the first impeller parameters was investigated, as well as the influence of the outlet chamber on the last diffuser blade row. Combined vane diffusers, which merge a long vaneless part and a low blade density part, were implemented in all stages. The numerical investigations confirmed the advantages of this solution: a wide operating range and reduction of the losses in the stator elements (as with vaneless diffusers), but at the same time providing optimal flow conditions at the inlet of the return channels, which leads to an efficiency increase (as with vane diffusers).
The main challenge to solve for the return channel optimization was the axial flow direction at the inlet of the next impeller. Traditional return channels with 2D profiles that we analyzed could not provide the axial flow direction on all channel spans. There were highly non-uniform flows on the hub and shroud, as shown in Figure 3 on the left side.
To solve this problem, we developed a non-classic return channel consisting of two parts: a 2D main profile part and a 3D outlet part. The main part was calculated in a way that would achieve the largest possible flow irregularity decrease, and the 3D outlet part was designed to have an effective flow alignment on all spans. This solution suppressed the secondary flows in the return channels considerably. In Figure 3, on the right side, where 90° equals axial flow, the irregularities after the modernization can be seen. The redesigning of the return channels eventually resulted in an increase of the operating range of the second and third impellers of more than 15% thanks to the improved impeller inflow conditions.
The new compressor performance map was calculated again for different operating conditions, i.e., different angles of incidence of the Inlet Guide Vane (IGV) and inlet temperature. The results are shown in Figure 4.
Meshing
The full mesh model of the compressor was generated with IGG and OMNIS/AutoGrid. It included about 40 million elements and consisted of all blade rows, gaps between impellers and stator, outlet chamber, and all labyrinth seal regions. The Spalart-Allmaras turbulence model for simulations was applied to verify the correspondence of mesh criterion y+ with a recommended range. Thanks to the high quality of the mesh, we could apply the CPU Booster for our calculations, which saved us a lot of time and computing resources.
Results
Industrial tests of the modernized compressor showed an increase of polytropic efficiency on normal mode of ~6.5% abs. and a corresponding decrease in power consumption of the same percentage. The new compressor reaches a higher pressure ratio of 4.5, compared to 4.1 before the modernization. Furthermore, the surge margin related to the normal mode significantly increased from ~6% before to 50% after. Power consumption on minimal performance is 1.5 times lower (~2.5MW).
The new, modernized compressor is in operation at the client site and performing well, and equally as important is proving reliable.
