  3. Capture not able to generate pcb editor netlist files
  • Replies 10
  • Subscribers 167
  • Views 19788
Bhuwan Sahni
Bhuwan Sahni over 15 years ago
 Whwn I prepare any project in orcad capture and then create netlist for the Pcb Editor and i chose the option to open the board file in allegro pcb editor . When i click ok it just displays the message that the project will be saved prior to netlisting and i chose ok.
After it nothing happens . no files are generated and PCB Editor does not open. I have added the allegro.cfg file in setup option.
The design is ok.
Help Me Please????
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    I would check the session log in Capture, did the netlist operation complete without any errors?`Typically if nothing happens its because the netlister did not complete its tasks.
    Can you copy the content from your session log (Windows->Session log) so that we can help determine the cause of this problem.
    Best regards
    Ole
  • Bhuwan Sahni
    Actually the session log does not show anything It is blank. In the create netlist box when I click ok. It just says design will be saved prior to netlisting. I clicked Ok and nothing happens.
    I have done the design rules check and it was successful. Its output in session log is
    Checking Schematic: SCHEMATIC1
    Checking Electrical Rules
    Checking For Single Node Nets
    Checking For Unconnected Bus Nets
    Checking Physical Rules
    Checking Pins and Pin Connections
    Checking Incorrect Pin Group Assignment
    Report for Invalid References
    Report for Duplicate References
    Checking Entire Design: SAMPLE
    Checking Power Pin Visibility
    Checking Normal Convert View Sync
    Checking Missing Pin Numbers
    Checking Device with Zero pins
    Checking Missing PCB Footprint Property
    Checking Name Property for Hierarchical Instances
    Check High Speed Properties Syntax
    Check Power Ground Mismatch
    Reporting Unused Refdes in multiple part packages
    Part                           Quantity                           Reference
    I am using Win 7 64 bit home Premium and orcad 16.3 . Is it to do anything with the version of windows??  Or there is a problem with the installation of Orcad??
  • Bhuwan Sahni
     I uninstalled and then reinstalled the product.
    Thes time when I go for to create the netlist capture gives me an error which reads : Error initialising COM property pages: Invalid Pointer.
    Help Please????
  • Cadpro2K
    Cadpro2K over 15 years ago
    Hi Bhuwan.
    If it's ok, please send me the .dsn file and I'll run the netlister and see what errors occur on my side. I've been using Capture/Allegro interface for years and have seen most all problems. I would be able to see something wrong within the schematic. I don't care about the design content - only helping out (e.g. your database will be deleted from my machine as soon as I figure out your problem).
    mailto: cadpro2k@yahoo.com
  • oldmouldy
    oldmouldy over 15 years ago
    You will need to go to the Capture shortcut, or Capture CIS shortcut (if that is what you are using), and right-click>Run as Administrator to get the software components correctly registered. This is a known issue with Windows Vista and Windows 7 when UAC is enabled.
