  3. PSpice installation on Windows 7
  • Replies 16
  • Subscribers 167
  • Views 34640
Xavras
Xavras over 15 years ago
I tried to install PSpice 9.1 Student Version on my Windows 7 and I always get the same problem. I doubleclick the setup.exe file but the installation never starts. I tried running it as an admin or using compatibility modes, but it doesn't help. The setup appears in the task manager, but it doesn't run. Does anyone know what to do with that?
  • paragc
    paragc over 15 years ago
    Try the following - Select setup.exe and from RMB (right mouse button) use "Run as Administrator"
  • Xavras
    Sadly it doesn't help.
  • oldmouldy
    oldmouldy over 15 years ago
    I think that you may find that the 9.x, and earlier versions, use a 16-bit installer for the 32-bit applications, Windows 7 won't run a 16-bit application - other users have reported getting a message that the application "is not a 32 bit application or a 64 bit compatible application" You need to get the latest software installed to work with Windows 7.
  • paragc
    Just checked again - PSpice Student version 9.1 with web update 2 - installs and works fine - on Windows 7 (32bit) if you use "Run as Administrator" on setup.exe . It will give you a warning after install but you can select that application is installed correctly. Your problem may be specific to machine.
    You can also pick the 16.3 demo from http://www.cadence.com/products/orcad/pages/downloads.aspx#pspice - there is a specific Capture/PSpice bundle.
  • Felipe Vignon
    Felipe Vignon over 15 years ago
    I had the exact same problem, windows 7 64-bit as well.
    Turned out all I needed to do was shut down Google Chrome, apparently. The minute I closed Chrome, the setup screen popped-up.
    Don't know why, but it worked.
