  3. From Orcad Capture Schematic to PCB Layout
  • Subscribers 158
  • Views 14733
Lindaros
Lindaros over 14 years ago
Cadence: Release 16.3
OS: Windows 7 - 32-bit
1) Create the simple circuit:I connected the resistor with GND and Power only no other special IC or other component.
2) Netlist: No Error
3) DRC file:
Checking Schematic:  SCHEMATIC1
Checking Electrical Rules
Checking For Single Node Nets
WARNING:  [DRC0006]  Net has fewer than two connections GND
                    SCHEMATIC1, PAGE1  (3.80, 1.50)
WARNING:  [DRC0006]  Net has fewer than two connections VCC
                    SCHEMATIC1, PAGE1  (3.80, 0.80)
Checking For Unconnected Bus Nets
Checking Physical Rules
Checking Pins and Pin Connections
Checking Incorrect Pin Group Assignment
Report for Invalid References
Report for Duplicate References
Checking Entire Design: TESTING1
Checking Power Pin Visibility
Checking Normal Convert View Sync
Checking Missing Pin Numbers
Checking Device with Zero pins
Checking Missing PCB Footprint Property
Checking Name Property for Hierarchical Instances
Check High Speed Properties Syntax
Check Power Ground Mismatch
Reporting Unused Refdes in multiple part packages
Part                           Quantity                           Reference
4) BOM List:
Item Quantity Reference Part
   1        1            R1      220
5) Create Netlist:
I check the "Create or Update PCB Editor Board (Netrev), and then i get popup "Info: Netrev succeeded with warning. Please refer to Session log or netrev.lst for details."
6) At Orcad PCB Designer:
popup: "WARNINGS(SPMHOD-33): Database was last saved by a higher tier tool…… Allegro Expert .There may be constraints,Rules and other design data that may be ignored in this tool."
Can somebody help me to solve this problem or can somebody teach me how to create PCB layout step by step and I want to know how to create my own pad fooprint with info "Recomended Solder Pad pitch and dimenesion" from datasheet.
Need feedback from somebody.
  • Lindaros
    And also i would like to know what application is suitable for creating PCB layout from schematic (using Orcad Capture)?
