  3. How to create two or three key strokes bindkeys
  • Replies 21
  • Subscribers 152
  • Views 35653
SlimAnt
SlimAnt over 16 years ago
How can I create two or three key strokes bindkeys without changing the existing bindkeys?
For example, addition of existing bindkeys such as: m -> to activate move
I would like to create new bindkeys such as: jmp -> SKILL code to jump to a certain coordinate
I tried using the following function getc to read the next character from keyboard and it doesn't work.
   procedure( call_2()
        TT = getc()
                if( TT = "p" then
                     ; function to jump
   procedure( call_1()
          TT = getc()
                 if( TT = "m" then
                        call_2()
hiSetBindKey("Layout" "none<Key>j" "call_1()")
I am using version IC6.1.3
I Appreciate any help that I can get.
    I had originally planned to describe an outline of a way to do this - but realised that as I started writing the outline, I wasn't that far off having the code itself. So I put together the code below which is a way to implement what I've called "sequence" bindkeys.
    Rather than having to code each specific combination (as in the code in the original post) you register a SKILL action against particular sequences.
    Anyway, the comments at the top of the code should explain things clearly enough.
    /* abSeqBindKey.ils
    Author     A.D.Beckett
    Language   SKILL++ (keep the .ils suffix on this file)
    Date       Oct 22, 2009
    Modified
    By
    A package to support sequence bindkeys. This means you can define multi-key
    bindkeys. So for example, you can define a bindkey "chop" - you type the four
    characters c, h, o, and then p - and this then triggers the bindkey.
    The sequence is displayed as a banner label so you can see the current
    sequence. Escape is normally used to reset the sequence.
    Note this is really a proof-of-concept - it is not fully formed, and may
    need some enhancement.
    ; Initialize the a-z, A-Z, and 0-9 bindkeys to be entry keys
    ; and escape to be a reset key for Layout application
    abSeqBindKey->initBindKeys("Layout")
    ; give warning if any key sequence defined which obscures another
    ; for example, "ed" obscures "edit"
    abSeqBindKey->option(?checkObscured t)
    ; Define some key sequences
    abSeqBindKey->set("Layout" "fit" "hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9)")
        ("copy" "leHiCopy()")
        ("chop" "leHiChop()")
        ("del"  "leHiDelete()")
        ("undo" "hiUndo()")
    ; Retrieve bindkeys:
    abSeqBindKey->get("Layout") => returns all the keys
    abSeqBindKey->get("Layout" "chop") => "leHiChop()"
    ; If you want to define your own bindkeys (rather than using initBindKeys)
    ; then you'll need to use these:
    abSeqBindKey->enter("X") ; enters an X in the sequence
    abSeqBindKey->reset()    ; resets the sequence
    Limitations:
    Doesn't have the concept of "Enter Function" bindkeys which are
    different during enter functions. Could do, but needs some thought
    as to a sensible use model.
    SCCS Info: @(#) abSeqBindKey.ils 10/22/09.13:44:45 1.1
    importSkillVar(abSeqBindKey)
    abSeqBindKey=let(
        ((bindkeys makeTable('bindkeys nil)) obscuredCheck)
        *                     initBindKeys(appType)                      *
        * EXPORTED function to initialize the bindkeys a-z, A-Z and 0-9, *
        *  as well as Escape, to work with the sequence bindkey system.  *
        defun(initBindKeys (appType)
            let((appRoot)
                appRoot=hiGetBindKeyInheritRoot(appType)
                when(appRoot
                    ; Define bindkeys for a-z, A-Z and 0-9
                    for(ascii charToInt('a) charToInt('z)
                        hiSetBindKey(appRoot
                            strcat("<Key>" intToChar(ascii))
                            sprintf(nil "abSeqBindKey->enter(\"%s\")"
                                intToChar(ascii))
                            strcat("Shift<Key>" intToChar(ascii))
                                upperCase(intToChar(ascii)))
                    ) ; for
                    for(ascii charToInt('\0) charToInt('\9)
                                intToChar(ascii))
                    ) ; for
                    hiSetBindKey(appRoot "<Key>Escape" "abSeqBindKey->reset()")
                ) ; when appRoot
            ) ; let
        ) ; defun initBindKeys
        *                              enter(char)                              *
        *   EXPORTED Function to enter a character in the sequence. If there    *
        *     is a sequence bindkey registered for that sequence, reset and     *
        *       then execute the bindkey definition - otherwise continue        *
        * collecting the characters in the sequence (and display in the banner) *
        defun(enter (char)
            let((win appType appRoot bindkeyTab defn sequence)
                win=hiGetCurrentWindow()
                when(win
                    sequence=strcat(win~>abSequence || "" char)
                    win~>abSequence=sequence
                appType=win && hiGetAppType(win)
                when(appType
                when(appRoot
                    ; Look up the bindkey definition. If found, then
                    ; reset the sequence and evaluate it, otherwise just
                    ; append the current sequence.
                    bindkeyTab=bindkeys[appRoot]
                    defn=bindkeyTab && bindkeyTab[sequence]
                    if(stringp(defn) then
                        reset()
                        errsetstring(defn t)
                    else
                        hiChangeBannerLabel(
                            strcat("Seq: " sequence)
                            0
                    ) ; if bindkey found
                ) ; when appRoot
            ) ; let
        ) ; defun enter
        *                           reset()                            *
        *       EXPORTED function to reset the current sequence        *
        defun(reset ()
            hiGetCurrentWindow()~>abSequence=""
                "Seq: "
                0
        ) ; defun reset
        *                    check(bindkeyTab key)                     *
        *  INTERNAL function to check that a new key sequence is not   *
        *    obscured by another, or does not obscure another. Only    *
        *      checked if option(?checkObscured t) has been used.      *
        defun(check (bindkeyTab key)
            let((len subKeyName)
                when(obscuredCheck && stringp(bindkeyTab[key])
                    len=strlen(key)
                    ; Look for any existing key sequences which the new key is
                    ; the beginning part of
                    foreach(keyName bindkeyTab
                        when(key!=keyName && zerop(strncmp(key keyName len)) &&
                            stringp(bindkeyTab[keyName])
                            warn("Definition for sequence %s will obscure sequence %s\n"
                                key keyName)
                        ) ; when
                    ) ; foreach
                    ; Look for any key sequences which are shorter than the new key
                    for(sub 1 sub1(len)
                        subKeyName=substring(key 1 sub)
                        when(stringp(bindkeyTab[subKeyName])
                                subKeyName key)
                        ) ; when
                    ) ; for
            ) ;let
        ) ; defun
        *                   set(appType key [defn])                    *
        *  EXPORTED function to set one or more sequence bindkeys for  *
        *                        an application                        *
        defun(set (appType key @optional defn "tg")
            let((appRoot bindkeyTab)
                when(appRoot
                    unless(bindkeyTab
                        bindkeyTab=makeTable('appBindkeys nil)
                        bindkeys[appRoot]=bindkeyTab
                    ; Handle list of definitions, and individual definitions
                    if(listp(key) then
                        foreach(keyDefn key
                            if(listp(keyDefn) && length(keyDefn==2) then
                                bindkeyTab[car(keyDefn)]=cadr(keyDefn)
                                check(bindkeyTab car(keyDefn))
                            else
                                warn("Key definition %L is invalid\n" keyDefn)
                    else
                        bindkeyTab[key]=defn
                    t
                ) ; when appRoot
            ) ; let
        ) ; defun set
        *                        get(appType [key])                        *
        * EXPORTED function to get one or all sequence bindkey definitions *
        defun(get (appType @optional key "tg")
                when(appType
                    ; If the key argument provided, just return the definition
                    ; otherwise return an assoc list of the whole lot
                    if(key then
                        bindkeyTab && bindkeyTab[key]
                    else
                        tableToList(bindkeyTab)
                ) ; when appType
            ) ; let
        ) ; defun get
        *                  option(@key checkObscured)                  *
        *       EXPORTED function to set any options. Currently        *
        *                     just ?checkObscured.                     *
        defun(option (@key checkObscured)
            obscuredCheck=checkObscured
        ; DPL containing all the package functions available from outside
        `(nil
            initBindKeys ,initBindKeys
            enter ,enter
            reset ,reset
            set ,set
            get ,get
            option ,option
    ) ; let
  • SlimAnt
    Thank you very much for your solution.
    Wow, It is not as simple as I thought.
    I am a new comer to this programming; thus, I will find time to digest these complicated codes.
    Thanks again,
    SlimAnt
    Hi SlimAnt,
    The code is not actually that complicated (a lot of it is comments); what I did however was to come up with a generic solution which allows registration of the bindkeys, rather than hard coding a specific solution (which is what your trial code was doing). I think you'll find that after you've defined a few bindkey combinations, the code I provided is much simpler than it would have been if you'd coded some complex "state machine" type representation.
  • SlimAnt
    Thank you for your follow up which was encouraging.
    I have read it and now understand on how to use. This is much better than what I had in mind.
    I am so happy for this. Just as happy as a kid getting a new toy.
    Thanks again,
    SlimAnt
  • kbhow
    kbhow over 16 years ago
    Nice coding. =D
    You are great Sifu (Guru).
    How
  • Mwcaboose
    Mwcaboose over 12 years ago
     Can this be made to work with Shift/Ctl/Alt as well?
    In principle, yes. You'd have to change initBindKeys to add bindings for modified keys - and this would need to call the ->enter function with some sequence to identify that unambiguously. Currently the ->enter gets called with a single character, e.g. "a", "B", "0" - but there's no reason why it couldn't be something else - e.g. "^D" to represent control-D - and then you enter that in your sequence definitions.
    Whether it's really what you want, I'm not sure - this is a bit of an all or nothing solution.
    Note, I didn't try changing it as described above - but from a quick glance back through the code (and I did write it getting on for 5 years ago), I think that should be possible.
  • theopaone
    theopaone over 12 years ago
    Hi  Andrew,
    This is great code.  It takes me back to GDS-1 (1970's) where every command was a two or three key sequence. You could get pretty good with a single hand on the keyboard and another with the pen (no on-screen menus).
    I'm going to use this to add special functionality with multiple key sequences, like emacs.
     Ted
  • Varungr087
    Varungr087 over 7 years ago in reply to Andrew Beckett
    Thanks for the code. It works great !
    But after I initialise the code, the default bindkeys of virtuoso like f(fit screen) are not working. Seems like I have to de-initialise the code. How do I do it
    Andrew Beckett over 7 years ago in reply to Varungr087
    That's inevitable. The code works by redefining all the letter and number keys so that it can detect what keys you've pressed. If it left the original bind keys alone (e.g. the "f" key), then you wouldn't be able to have "f" in any key sequence!
    The examples in the comments show "fit" being defined for this. You could of course adapt that and use "f" instead, but then you wouldn't be able to have any other sequence which begins with 'f". So it's a compromise:
    abSeqBindKey->set("Layout" "f" "hiZoomAbsoluteScale(hiGetCurrentWindow() 0.9)")
