  3. format output the captab
  • Views 18130
imagesensor123
imagesensor123 over 14 years ago
 Hi all,
    for some limitation in IC5141, i can't print the capacitance captab out perfectly, so i specifiy a file where the cadence can save all the node capacitance.  the file content looks like belowing:
Capacitance Table `tran-000_capInfo'
Capacitance values computed in Tran analysis `tran' at time = 1 ms (T = 27 C).
MCOLUMNAMP:int_d : MCOLUMNAMP:int_d     fixed=106.999 a    variable=2.72777 f
        sum=2.83477 f
MCOLUMNAMP:int_s : MCOLUMNAMP:int_s     fixed=106.999 a    variable=2.71843 f
        sum=2.82542 f
net7 : net7     fixed=245.898 a    variable=1.41725 f    sum=1.66315 f
net11 : net11   fixed=245.898 a    variable=516.947 a    sum=762.845 a
net15 : net15   fixed=245.898 a    variable=462.625 a    sum=708.523 a
Vout : Vout     fixed=151.313 f    variable=2.72601 f    sum=154.039 f
vdd! : vdd!     fixed=0            variable=0            sum=0
Pixel1.MFOLLOWER:int_d : Pixel1.MFOLLOWER:int_d fixed=222.216 a
        variable=2.44684 f    sum=2.66906 f
Pixel1.MFOLLOWER:int_s : Pixel1.MFOLLOWER:int_s fixed=222.216 a
        variable=2.75089 f    sum=2.97311 f
Pixel1.MRESET:int_d : Pixel1.MRESET:int_d       fixed=106.999 a
        variable=1.48203 f    sum=1.58903 f
Pixel1.MRESET:int_s : Pixel1.MRESET:int_s       fixed=106.999 a
        variable=1.58627 f    sum=1.69327 f
Pixel1.MSELECT:int_d : Pixel1.MSELECT:int_d     fixed=106.999 a
        variable=935.721 a    sum=1.04272 f
Pixel1.MSELECT:int_s : Pixel1.MSELECT:int_s     fixed=106.999 a
        variable=1.57613 f    sum=1.68313 f
Pixel1.net8 : Pixel1.net8       fixed=31.9 a       variable=5.45466 f
        sum=5.48656 f
Pixel1.net18 : Pixel1.net18     fixed=508.232 a    variable=63.5291 f
        sum=64.0374 f
 there are too much infomation,  i tried to extracted only the Vout node capacitance, i used a script as "grep "Vout" capinfo.txt >Voutnodecap" , and in the Voutnodecap , the results show like following:
Vout : Vout     fixed=151.313 f    variable=2.74593 f    sum=154.059 f
Vout : Vout     fixed=151.313 f    variable=2.79785 f    sum=154.111 f
Vout : Vout     fixed=151.313 f    variable=3.24377 f    sum=154.557 f
Vout : Vout     fixed=151.313 f    variable=3.24482 f    sum=154.558 f
Vout : Vout     fixed=151.313 f    variable=3.24652 f    sum=154.559 f
Vout : Vout     fixed=151.313 f    variable=2.85435 f    sum=154.167 f
Vout : Vout     fixed=151.313 f    variable=2.85957 f    sum=154.172 f
Vout : Vout     fixed=151.313 f    variable=2.87133 f    sum=154.184 f
Vout : Vout     fixed=151.313 f    variable=2.86097 f    sum=154.174 f
it looks fine now, but the above Vout capacitance is extracted from different time points, such as timePoints=[1m 3m 6m 6.5m 7m 8m 10m 11m 20m 30m]
so what i want to know now is how to arrange the above data into a file like the followings automatically:
1m  154.039 f
3m  154.059 f
6m  154.111 f
do you have some experience? no matter which function you used, skill or shell script is ok.
    Not quite sure why you can't use ocnPrint for this - e.g. ocnPrint(pv("Vout : Vout" "Total" ?result "tran_info:tran_info"))
    From my example:
     ocnPrint(pv("Q58a:int_b : Q58a:int_b" "Total" ?result "tran_info-tran_info") ?output "cap.out")
    Which produces:
     time              pv "Q58a:int_b : Q58a:int_b" "Total" ?resultsDir "/export/home/andrewb/demos/SpectreRF/simulation/ne600/spectre/schematic" ?result "captab"
    99n                   1.1551p
    134n                  1.17948p
    175n                  1.14999p
    Alternatively if you want to do it from an ASCII output file, something similar to this would do the job (not thoroughly tested, I would suggest you clean this up and modify it yourself):
    #!/usr/bin/env perl
    # Author     A.D.Beckett
    # Group      Custom IC, Cadence Design Systems Ltd
    # Machine    SUN
    # Date       Mar 01, 2012
    # Modified
    # By
    # processCaptab pattern fileName
    $pattern = shift;
    while (<>) {
        if ($_ =~ /Capacitance values .* at time/) {
            # do some substitution to extract out the time without
            # any whitespace and also with the "s" units removed
            s/^[^=]*= //;
            s/[(].*//;
            s/\s*//g;
            s/s$//;
            $currentTime=$_;
        if ($_ =~ /$pattern/) {
            $collect=1;
            $line="";
        if ($collect && $_ =~ /^\s*$/) {
            $collect=0;
            $line =~ s/^.*sum=//;
            $line =~ s/\.\s*$//;
            $line =~ s/\s*//g;
            print $currentTime."  ".$line."\n";
        if ($collect) {
            $line=$line.$_;
    So I did something like:
     processCaptab Q58a:int_b input.info.captab
    and got:
     99n  1.1551p
    134n  1.17948p
    175n  1.14999p
    Take your pick!
  • imagesensor123
        yes, the same question, i have diffculty in understanding your script above, it's a perl script. your method is also search a "pattern" in the file and then pick the vaule up?
    Yes. You could use "processCapTab Vout fileName" in your other post's example. It's not that complicated a perl script - look at a book on perl (e.g. one of the O'Reilly books).
    If you only want the numbers, you could do:
    grep 'Vout' fileName | awk -F= '{print $NF}'
    or
    awk -F= '/Vout/{print $NF}'
    these use = as the field separator, and then print the last field (NF is a special variable in AWK which is the number of fields on a line). See "man awk" for more details.
    or you could use the SKILL approach.
    There are at least 20 ways to skin  the cat.
    Andew.
  • imagesensor123
         thanks a lot, just a little problem, can i try to use the following function,
    csh("grep 'Vout' capdataFile | awk -F= '{print $NF}' > capValueFile")
    and i got all the capdata in the capValueFile, but the function "grep 'Vout' capdataFile | awk -F= '{print $NF}' > capValueFile" works well if i use it in the terminal,  the "csh" can't work in this case?
  • imagesensor123
       I use "sh" to replace "sch", it's ok now, thanks Andrew.
    have a good weekend!
