  3. SKILL code to traverse the hierarchy of cellviews in sc...
  • Views 19429
SKILL code to traverse the hierarchy of cellviews in schematic
Atul Dwivedi
Atul Dwivedi over 12 years ago
Hi there,
I have been stuck for quite sometime with a requirement, to access the parameter values of each instance (MOS, RES, CAP, VDC...) in a design which has instances of many other cell view, hence creating a hierarchy (These sub-cell views translate to subcircuits in the netlist) .
What I want is, to be able to access recurisively each instance in the design and be able to change the 'w's and 'l' etc. from the top cell view.
As a starting point I have collected some information and coded the following:
currentSession=asiGetSession(hiGetCurrentWindow())
topCellView=asiGetTopCellView(currentSession)
Now where to head next? Can anyone suggest?
Thanks and Regards,
Atul
  • marcelpreda
    marcelpreda over 12 years ago
    Hi Atul,
    See bellow a starting example.
    The idea:
    - scan all instances in the cell
    - if your isnt has an schematic view descend in it
    - if no schematic view available I assume that it is a primitive (I print for it lib/cell)
    you should decided the "primitives" lib/cell which are interesting  for you.
     If your design is big the code bellow may slow,
    think of a nonrecursive implementation, or to not visist the already seen lib/cell/view .
    BR,
    Marcel
     ;; traverse schematic hier
    ;; and print all the instances that do not have any schematic view
    ;; most likely those are your primitives
    ;; cv - cv to scan
    ;; level - level down into hierarchy, used just to indent the printed lines.
    procedure( mpTraverseHierSch( cv @optional (level 0) )
        foreach(inst cv->instances
            if( cview =  dbGetAnyInstSwitchMaster(inst "schematic") then
                mpTraverseHierSch(cview level+1)
            else
                ;; some preety  printing
                for( i 1 level
                    printf("    ")
                printf("%s %s/%s in %L\n"
                    inst->name inst->libName inst->cellName
                    list(cv->libName cv->cellName cv->viewName))
    mpTraverseHierSch(topCellView)
  • Atul Dwivedi
    Dear Marcel, That worked great! Thanks a lot for such a detailed solution. Regards, Atul
