  3. loading scripts using callback function
  • Subscribers 147
  • Views 15479
deep242003
deep242003 over 10 years ago
hi ,
 I want to create a form with some button . Clicking on button should load correponding .il file .
Please suggest how to pass load ("locaton .il" to call back function of hiCreateButtonBoxField.
  • skillUser
    skillUser over 10 years ago
    Ideally you would provide more detail in your question so that others can help you better.  However, here's an approach using a form with a filename field and an OK / Cancel set of buttons.  The example was written for the purpose of loading a cdsSession.save file, but you can adapt it to your needs...
    *                       CCSloadSession()                       *
    * A procedure to create a form for loading session files, both *
    *  the filename field and the form have callbacks associated   *
    *  with them.  The form is built the first time this function  *
    *            is called, and then it is displayed.              *
    procedure(CCSloadSession()
      let((filename form)
        unless(boundp('CCSloadSessionForm) && (form=CCSloadSessionForm)
            && hiIsForm(form)
          filename = hiCreateStringField(
                       ?name   'filename
                       ?prompt "File Name"
                       ?value  "cdsSession.save"
                       ?callback "CCSloadSessionFieldCB(hiGetCurrentForm())"
          form = hiCreateAppForm(
                    ?name      'CCSloadSessionForm
                    ?formTitle "Load Session"
                    ?buttonLayout 'OKCancel
                    ?fields    list(
                      list(filename 0:0 300:30 75) )
                    ?callback  'CCSloadSessionFileCB
                    ?unmapAfterCB t
        ); unless
        hiDisplayForm(form)
      ); let
    ); procedure CCSloadSession
    *                 CCSloadSessionFieldCB(r_form)                 *
    *  A callback function that tests if the filename field on the  *
    * Load Session form is a valid file or not.  If the file is not *
    *  valid the field is highlighted, otherwise the field appears  *
    *      normal.  This function returns the filename or nil.      *
    procedure(CCSloadSessionFieldCB(form "r")
      let((filename)
        if(isFile(filename=simplifyFilename(form->filename->value)) then
          hiHighlightField(form 'filename 'background)
          filename
        else
          hiHighlightField(form 'filename 'error)
          nil
        ); if
      ); let
    ); procedure CCSloadSessionFieldCB
    *                 CCSloadSessionFileCB(r_form)                 *
    * A callback function that first tests if the filename exists, *
    *   if not the form unmap is vetoed, the form remains on the   *
    *   screen with the filename field highlighted.  If the file   *
    *   does exist the filename field will appear normal and the   *
    *                       file is loaded.                        *
    procedure(CCSloadSessionFileCB(form "r")
    let((file)
      when(hiIsForm(form)
        if(file = CCSloadSessionFieldCB(form) then
          hiSetCallbackStatus(form t)
          CCSloadSessionFile(file)
        else
          hiSetCallbackStatus(form nil)
        );if
      );when
    );let
    ); procedure CCSloadSessionFileCB
    *                  CCSloadSessionFile(t_file)                  *
    * This function prints the filename and uses loadi to load it  *
    procedure(CCSloadSessionFile(file "t")
      printf("Loading file: %s\n" file)
      loadi(file)
    Here the OK button applies the form callback which loads the file if it exists. In your case it sounds as though the button would load a file, either a fixed filename, or perhaps another field's string value?
    Hopefully this helps?
    Lawrence.
