  3. Change purpose of the layer and replace it with other o...
  • Views 16350
Change purpose of the layer and replace it with other one
cs03
cs03 over 10 years ago
I want to change the purpose (i.e.-  drw/txt/lbl/pin) of the layer and replace one layer with other (i.e.-  M2 to M3 ) one using SKILL, how to do it? Are there functions defined for it?
  • Ferdz
    Ferdz over 10 years ago
    Hi Chandan,
    To give just an idea.
    ;;If you want to change metal layer to another
    Obj~>layerName = toNewLayer ;(must be string type)
    ;;to change purpose
    Obj~>purpose = toNewPin ;(must be string type)
    ;;to change Layer Purpose Pair
    Obj~>lpp = toNewLPP ;(must be a list type, ex (“metal2” “pin”)
    Where obj is a db object of the selected layer you want to change.
    sample code:
    procedure( changeMetalLayer( lyrName )
         let( (objList)
                objList = geGetSelectedSet( geGetEditCellView() )
                objList~>layerName = lyrName
         );let
    );proc
    if I want to change all selected metals to metal2, i call the procedure; changeMetalLayer( "metal2").
    regards,
    Ferdz
  • cs03
    Thanks for your help ferdz..
