  3. Agentic AI for Analog and Custom IC Design
Reela Samuel
Reela Samuel
agentic ai
AI in chip design
virutuoso
automation
Celsius EC Solver
analog
Spectre
analog design
Quantus
Custom IC
ViraStack AI Super Agent
4 Nov 2026 • 8 minute read
Analog IC design and custom IC design remain difficult to automate because circuit behavior depends on interactions among device characteristics, circuit topology, simulation results, and physical layout. Design intent is not always captured fully in formal specifications or scripts. Engineers often rely on experience to navigate technology constraints and tradeoffs among performance, power, area, and reliability.
Agentic AI offers a way to coordinate specialized engineering tasks, use available design context, and evaluate results across multiple stages of a workflow. Its potential value lies in reducing repetitive work without removing the engineering judgment needed to develop and validate analog circuits.
Why Analog Design Is Difficult to Automate
Analog design involves interdependent decisions. Changing transistor sizing, biasing, topology, or layout can affect several performance parameters at once. Improving gain, for example, may influence bandwidth, power consumption, noise, or stability.
Analog Circuit Design
Process, voltage, and temperature (PVT) variations add complexity because circuits must meet specifications across relevant operating corners, not just under nominal conditions. Physical layout introduces parasitic resistance and capacitance, device-matching considerations, and routing effects that can alter circuit behavior. A schematic that meets its targets may not retain the same performance after layout and parasitic extraction.
Specifications also do not always capture why a topology was selected, which tradeoffs were accepted, or which layout relationships must be preserved. This becomes particularly important when reusing existing IP or migrating a design to a different process node.
Traditional analog design automation addresses tasks such as simulation, parameter optimization, and aspects of layout generation. Research is extending this work to topology exploration, sizing, and broader design flows. Coordinating these activities reliably remains a challenge because design decisions depend on context, constraints, and results across multiple stages.
What Agentic AI Means for Analog Design
Agentic AI can interpret a task, retrieve relevant information, invoke engineering tools, evaluate intermediate results, and determine the next action within defined boundaries.
In an analog design workflow, an agent might retrieve a reference circuit, prepare a schematic or testbench, initiate a simulation, inspect results, and propose adjustments. The workflow can use the results of one stage to guide the next, rather than treating each task as an isolated operation.
The effectiveness of this approach depends on the information available to the agent, the tools it can access, and the criteria used to evaluate results. Circuit optimization, for example, requires more than changing component values. The workflow must account for design specifications, supported parameters, simulation conditions, and competing performance objectives.
Where Agentic Workflows Can Help Today
The strongest opportunities are tasks with defined objectives, accessible design context, and results that can be assessed using established engineering methods.
 Reusing Existing Analog IP
Finding a suitable reference circuit requires more than matching its function. Engineers need to understand its topology, specifications, technology dependencies, and verification status.
AI-assisted IP catalogs can help search for candidate designs using information such as circuit type, topology, specifications, and process technology. The results can provide a starting point for reuse or migration, subject to review of the original assumptions and the target design requirements.
 Schematic Capture and Testbench Development
Schematic creation and testbench preparation can involve repetitive setup, particularly when evaluating multiple operating conditions or design alternatives. Agentic workflows can help generate initial schematics and testbenches from supplied specifications, reference designs, and other available context.
Generated artifacts still require technical review. A schematic that is syntactically valid may not be electrically correct, and a testbench may fail to cover the operating conditions that matter to the design.
 Circuit Optimization and Debug
Agentic workflows can coordinate simulation runs, compare results with specified objectives, and support successive optimization iterations. This can help engineers explore alternatives while balancing requirements such as gain, bandwidth, noise, power, and stability.
Agents can also organize simulation evidence and suggest possible causes of failures. Engineers must establish whether those explanations fit the circuit behavior and validate any corrective action, particularly when several causes are plausible.
 Analog Layout Migration and Process Porting
Migrating a design to another process node can require changes to device choices, circuit parameters, layout structures, and verification procedures. Differences in design rules, device characteristics, and parasitic effects can affect both performance and manufacturability.
Agentic workflows can help identify source designs, carry forward available design context, and coordinate selected migration and verification tasks. However, migration is not simply the reproduction of existing geometry in a new technology. The resulting design must meet the target process requirements and pass the relevant electrical and physical checks, including design-rule checking, parasitic extraction, and simulation.
Where Human Judgment Remains Essential
Analog design involves tradeoffs rather than a single correct answer. Engineers must define objectives, select appropriate architectures, assess competing requirements, and determine whether a result is suitable for its intended application.
Three conditions are central to responsible automation:
  • Sufficient design context: The workflow needs the specifications, constraints, and design intent relevant to its task. Missing information can lead to inappropriate recommendations or changes.
  • Independent verification: A generated design or suggested correction is not evidence of correctness. Appropriate simulation, physical verification, and signoff procedures remain necessary.
  • Defined responsibility: Generating a first draft, recommending an optimization, executing a bounded task, and approving a production design are different levels of responsibility. The permitted scope of automation should reflect the task and its associated risks.
How Multi-Agent Workflows Manage Tasks
A multi-agent workflow divides a larger task among specialized agents or components. One may retrieve design information, another may prepare a simulation, and a coordinating component may manage task sequencing and evaluate results.
Separating information gathering from actions that modify a design can help control the workflow. For example, a research task may identify candidate reference circuits without changing the working design, while an execution task makes authorized changes within a defined scope.
Cadence’s Approach to Agentic AI for Analog and Custom IC Design
Cadence Virtuoso AI Studio, when paired with the Cadence ViraStack AI Super Agent, brings agentic AI directly into the analog and mixed-signal design environment. Instead of treating AI as a separate assistant, Virtuoso AI Studio places it alongside the tools and design context engineers already use, enabling AI to move from providing general answers or optimizing individual tasks to executing and coordinating parts of the design workflow.
AI Task Agents embedded within Virtuoso® AI Studio
The ViraStack AI Super Agent's design migration agent assists with this sequence, including topology mapping, device scaling, and optimization across technologies.
Cadence has demonstrated this approach in a 6 GHz analog/RF PHY migration flow, achieving 60% faster design closure. The value lies in connecting steps that traditionally require engineers to move between tools, analyses, and iterations manually.
Cadence's broader analog and custom IC portfolio includes technologies that support different stages of the design process:
Cadence’s broader analog and custom IC portfolio includes technologies for circuit design, simulation, optimization, physical verification, and thermal analysis. These include:
  • Spectre Simulation Platform: Circuit simulation and electrical performance analysis
  • iPegasus Verification System: Physical verification, including design-rule checking
  • Virtuoso ADE Artist and WiCkeD Tool Suite: AI/ML powered circuit optimization, yield optimization, and robustness analysis, supporting both pre-layout and post-layout optimization leveraging the WiCkeD algorithm
  • Quantus Extraction Solution: Parasitic extraction for post-layout analysis
  • Voltus-XFi Custom Power Integrity Solution: Transistor-level electromigration and IR-drop (EM-IR) analysis for power-integrity signoff, with an integrated flow for extraction, simulation, analysis, and debugging
  • Celsius Studio Platform: AI-enabled thermal and multiphysics analysis, including thermal analysis for custom IC and MMIC designs
These technologies address different aspects of analog and custom IC design. The ViraStack AI Super Agent’s role is to coordinate selected engineering tasks and reduce repetitive work while preserving the established simulation, verification, and signoff processes needed to validate a design.
Cadence has reported 60% faster design closure and 3.2X layout productivity for a specific 6 GHz analog/RF PHY example. Separately, Cadence has reported productivity improvements of up to 70% across Virtuoso design workflows spanning 130 nm to 3 nm, based on more than 80 production engagements.
FAQs
What is agentic AI in analog IC design?
Agentic AI in analog IC design coordinates specialized tasks, uses design context, invokes engineering tools, and evaluates intermediate results within defined constraints. Potential applications include IP reuse, schematic creation, simulation preparation, circuit optimization, and layout migration.
Can agentic AI automate analog circuit design completely?
No. It can assist with selected tasks, but design intent, competing performance requirements, technology constraints, and verification needs limit full automation. Engineering review and signoff remain essential.
How can agentic AI help with analog layout migration?
It can help identify source designs, carry forward available design context, and coordinate selected migration and verification tasks. The migrated design must still meet the target process rules and electrical and physical requirements.
What is ViraStack AI Super Agent?
The ViraStack AI Super Agent is Cadence’s AI Super Agent for custom and analog IC design. It is designed to coordinate selected engineering workflows, including IP reuse, schematic and testbench creation, circuit optimization, verification, and layout migration.
Does agentic AI replace analog design engineers?
No. It can reduce repetitive workflow effort, but engineers remain responsible for design decisions, tradeoffs, validation, and determining whether a circuit meets its requirements.
Explore Agentic AI for Analog and Custom IC Design
Agentic AI can help connect engineering tasks and reduce repetitive work in analog and custom IC design. Its value depends on applying automation to suitable workflows while retaining the validation needed for reliable results.
What Changes for the Analog Design Team?
Agentic AI can shift time away from repetitive setup and coordination toward design decisions, analysis, and validation.
Design activity
Potential contribution of agentic AI
Engineering responsibility
IP reuse
Find and organize relevant reference designs
Confirm suitability and technology compatibility
Schematic and testbench creation
Prepare initial artifacts and simulation setups
Review correctness and test coverage
Coordinate iterations and compare results with objectives
Evaluate tradeoffs across required conditions
Debug
Organize evidence and suggest possible causes
Establish root cause and validate corrective actions
Layout migration
Assist with selected migration tasks
Confirm physical correctness and signoff compliance
Teams can evaluate adoption by measuring engineering time spent on repetitive setup, the number of iterations needed to meet specifications, migration turnaround time, verification findings, and manual rework. Productivity should be assessed alongside design quality and completeness.
