  3. Agentic AI for PCB and Advanced Packaging Design
Reela Samuel
Reela Samuel
15 Oct 2026 • 8 minute read
As AI workloads grow, more engineering challenges extend beyond the chip itself to the package that brings compute, memory, power, and cooling together. The HBM4 standard is designed to increase memory bandwidth, while evolving stacking requirements add to the importance of power delivery and thermal management. Co-packaged optics bring optical engines closer to switching or compute ASICs, creating opportunities to support higher-bandwidth interconnects while introducing challenges in signal integrity, mechanical integration, and thermal design. 3D integration increases interconnect density and can concentrate heat, making placement, routing, and power-delivery decisions more consequential.
The challenge is to evaluate placement options, routing strategies, and package architectures against electrical, thermal, mechanical, and manufacturing constraints while limiting unnecessary design iterations and rework.
Agentic AI offers a way to coordinate this work through established EDA tools. Rather than automating only an individual placement or routing operation, an agentic design flow can coordinate multiple tasks and use analysis results to guide subsequent steps, helping engineers evaluate alternatives within defined constraints.
Why PCB and Packaging Workflows Are Difficult to Coordinate
Chip design has benefited from decades of mature automation. Synthesis, place-and-route, formal verification, timing signoff, and physical verification have progressively streamlined design implementation and verification. PCB and advanced-package development, by contrast, often requires coordination across layout, electrical and thermal analysis, mechanical engineering, and manufacturing.
This coordination becomes more demanding in 2.5D and 3D-IC designs. Multi-die systems, interposers, fan-out structures, HBM integration, and complex substrates introduce constraints that span silicon, package, board, and product enclosure domains. Although these domains may rely on separate tools and engineering workflows, their decisions are interdependent. A change in component or die placement, for example, can affect routing feasibility, signal integrity, power delivery, and thermal performance, triggering further design changes and analysis.
Evaluate Component Placement Alternatives Earlier
Component placement establishes many of the conditions that shape the rest of a PCB or package layout. These requirements can compete. Moving a high-power device may improve cooling but complicate its power connections. Shortening a critical signal path may increase congestion elsewhere.
AI-assisted placement can accelerate the evaluation of candidate arrangements against specified constraints, making it more practical to compare alternatives that would otherwise require substantial engineering time.
The Cadence AuraStack AI Super Agent can deliver up to 15X higher productivity and 2X faster time to market.
Accelerate Substrate Routing Without Compromising Quality
Advanced-package substrates connect dies, bridges, redistribution layers, and external interfaces through dense networks of interconnects. In AI and high-performance computing (HPC) designs, completing these connections within limited routing space and layer budgets can be a substantial implementation task.
A route must satisfy more than connectivity. Depending on the interface, it may need to meet impedance and crosstalk limits, preserve return paths, control layer transitions, and comply with substrate manufacturing rules. Changes to individual routes can also affect congestion and neighboring connections.
Cadence is advancing AI-driven automation for advanced-package implementation to help customers achieve design convergence for increasingly complex multi-die systems. In a multi-year collaboration, substrate autorouting using the AuraStack AI Super Agent demonstrated up to 100X higher productivity, with a quality of results comparable to manual routing.
Automating repetitive connections can free engineers to focus on difficult routes, critical regions, and cases that require engineering judgment. The resulting implementation must still meet the relevant electrical and manufacturing requirements.
Multiphysics Analysis Connects Findings to Design Changes
Thermal Analysis
A package can satisfy its placement and routing requirements yet still fail to meet electrical, thermal, or mechanical specifications. Signal-integrity analysis evaluates interconnect behavior, while power-integrity analysis examines power delivery under specified operating conditions. Thermal analysis assesses heat generation and dissipation; mechanical simulation evaluates stresses and deformation.
Consider a high-power device that meets its routing requirements but exceeds its temperature limit under the expected workload. Engineers may need to relocate the device or revise the cooling arrangement. Either change can affect signal paths, power connections, and routing space.
Addressing the thermal issue may require relocating the device or revising the cooling arrangement, followed by renewed checks of routing feasibility and electrical and thermal performance.
An agentic design flow can coordinate these steps by identifying relevant tasks, invoking available tools, and using their results to determine what needs to happen next. The analyses themselves remain grounded in the underlying simulation tools, which evaluate the design against the applicable physical models and constraints.
AuraStack AI Super Agent Coordinates PCB and Advanced-Packaging Workflows
The Cadence AuraStack AI Super Agent brings agentic AI to PCB and advanced packaging design. Powered by Allegro AI Studio it works from engineering intent expressed in natural language and coordinates tasks across the design workflow using Cadence implementation and analysis technologies.
The AuraStack AI Super Agent is tightly integrated with Cadence solutions for PCB design, IC packaging, and multiphysics analysis, including Allegro AI Studio, Allegro X Design Platform, Allegro X Advanced Package Designer, Sigrity X Platform, Clarity 3D Solver, and Celsius Studio Platform.
A central part of this approach is its mental model, a contextual representation of the design that captures its hierarchy, relationships, constraints, and engineering intent. This model provides the context that the AuraStack AI Super Agent uses to plan and run tasks, rather than treating each request as an isolated operation. Results from implementation and analysis can inform subsequent steps, helping preserve design intent across successive tasks.
The AuraStack AI Super Agent supports workflows spanning system planning, library and constraint management, placement, routing, design for manufacturability (DFM), and multiphysics analysis. The tasks it can coordinate depend on the design environment, available data, tool integration, and engineering controls. The underlying EDA tools perform the design and physics-based analysis, with engineers reviewing results and validating that the design meets its requirements.
Adopting Agentic Workflows with Engineering Oversight
agentic workflow
Teams adopting agentic workflows can start with bounded tasks such as library creation, constraint capture, component placement, and repetitive substrate routing. They can then extend the automation to broader implementation and analysis workflows as tool integration and validation processes mature.
Engineers need to define the design intent and constraints, determine which tasks can be delegated, and specify the checks required before accepting results. Architectural decisions and changes affecting critical performance margins or compliance require appropriate engineering review.
Productivity should be measured alongside design quality. Useful measures include the number of design iterations and rework loops, late-stage violations, the number of viable placement candidates or routing strategies evaluated, and the effort required to validate the resulting design. Faster execution alone does not demonstrate an improvement if it creates additional downstream work.
Applying Agentic AI to System-Level Design
PCB and advanced-package design increasingly requires engineers to evaluate electrical, thermal, mechanical, and manufacturing constraints together. Agentic AI offers a way to coordinate more of this work within established EDA workflows, helping teams explore design alternatives and manage iterations as system complexity grows.
FAQs About Agentic AI for PCB and Advanced Packaging Design
What is agentic AI in PCB and advanced packaging design?
Agentic AI coordinates multi-step engineering tasks across PCB and advanced-package design workflows. Rather than automating only an individual operation, an AI agent can interpret engineering intent, plan relevant tasks, invoke connected EDA tools, and use their results to guide subsequent steps. This helps engineers evaluate design alternatives while working within defined constraints and engineering controls.
How does agentic AI differ from conventional EDA automation?
Conventional EDA automation typically executes defined operations, optimization routines, or rule-based workflows. Agentic AI adds a coordination layer that can use engineering context and task results to determine subsequent actions across connected tools. The underlying EDA tools still perform implementation and physics-based analysis; the agent coordinates the workflow rather than replacing those capabilities.
How can agentic AI improve PCB and advanced-package design productivity?
Agentic AI can help automate repetitive implementation tasks, coordinate work across tools, and evaluate placement or routing alternatives more efficiently. Potential benefits include reduced manual effort, fewer unnecessary iterations, and more time for engineers to address difficult routing problems and critical design tradeoffs. Actual productivity gains depend on the task, design complexity, tool integration, and validation requirements.
How does agentic AI support signal integrity, power integrity, and thermal analysis?
An agentic workflow can coordinate relevant implementation and analysis tasks, using findings from one step to inform subsequent actions. For example, a thermal analysis result may prompt a placement or cooling change, followed by checks of routing feasibility, signal integrity, and power delivery. The underlying simulation tools evaluate the design using their applicable physical models and constraints.
What is the AuraStack AI Super Agent, and how does it support PCB and advanced-package design?
The Cadence AuraStack AI Super Agent, powered by Allegro AI Studio, brings agentic AI to PCB and advanced-package design. It uses engineering intent expressed in natural language and a contextual representation of the design, called a mental model, to coordinate tasks across supported implementation and analysis workflows. Its scope includes system planning, library and constraint management, placement, routing, design for manufacturability, and multiphysics analysis, depending on the design environment and available tool integrations.
Can agentic AI replace engineers in PCB and advanced-package design?
No. Agentic AI can coordinate tasks and automate portions of implementation, but engineers remain responsible for defining design intent, setting constraints, reviewing results, and validating the design. Architectural decisions and changes affecting critical electrical, thermal, mechanical, or manufacturing requirements still require appropriate engineering judgment and verification.
How should engineering teams measure the value of agentic AI?
Teams should measure productivity alongside design quality. Useful indicators include time spent on repetitive tasks, design iterations and rework loops, late-stage constraint violations, the number of viable placement or routing alternatives evaluated, and the effort required to validate results. Faster execution alone does not demonstrate value if it increases downstream rework or compromises design requirements.
Explore how Cadence AI Super Agents apply this approach to digital implementation and signoff in the next blog.
Ready to explore agentic AI for your design workflow?
