  3. Inference Silicon: NPUs, AI Accelerators, and AI Co-Pro…
Vinod Khera
Vinod Khera
agentic ai
inference
AI Accelerator
NPU
AI
Inference Silicon: NPUs, AI Accelerators, and AI Co-Processors
18 Nov 2026 • 8 minute read
AI is evolving beyond single models responding to individual prompts. Today’s agentic systems can perceive, reason, plan, use tools, and act in the physical world. This shift has made inference the dominant workload in modern computing, creating demand for hardware designed to deliver speed, efficiency, and cost control.
Inference silicon is the hardware used to run trained AI models and generate results from new inputs. It includes dedicated neural processing units (NPUs), AI accelerators, and AI co-processors (AICPs). Although these terms are often used interchangeably, they describe technologies with distinct roles. Each sits at a different point in the system and addresses different bottlenecks. Understanding these distinctions is a first step toward designing silicon for agentic workloads—and translating model requirements into practical system architectures.
This blog post defines each category precisely, sets out what agentic workloads change, and explains how to evaluate inference silicon on the metrics that predict real-world performance.
The Taxonomy that Actually Matters
An NPU is itself a type of AI accelerator. It is a neural processing unit: hardware designed to efficiently implement neural network computation.
An AI accelerator is a broader category. It can include an NPU, GPU, DSP, or purpose-built ASIC, depending on the context. In a system on chip (SoC), an accelerator is generally optimized for specific computational patterns such as matrix multiplication, convolutions, or transformer attention—rather than serving as a general-purpose CPU.
An AICP is a complementary processing role that works alongside an NPU.
Cadence’s Tensilica NeuroEdge AICP is explicitly intended to pair with Cadence Neo NPUs, in-house NPUs, or third-party NPU IP to form a more complete AI subsystem.
What Agentic Workloads Change About Inference Silicon
Agentic AI introduces a more varied inference workload. For LLM-based applications, memory capacity and bandwidth become particularly important during token generation, as the system must retain and access the growing key-value (KV) cache. At the same time, efficient, low-precision computation and optimization across the complete inference pipeline are essential to meeting performance and power targets.
Memory capacity and bandwidth become first-order. Agentic sessions maintain a large key-value (KV) cache and constantly reread it. An inference part is now specified as much by how much state it can hold and how fast it can stream it as by its peak throughput. This is why architectural bets in this category increasingly differ in memory rather than in compute.
Low-precision arithmetic matters more than peak precision. Inference increasingly uses lower-precision formats, including INT8 and INT4, to reduce computation and memory requirements. Emerging microscaling formats offer additional opportunities to balance numerical accuracy and performance. However, the benefits depend on hardware support, compiler optimizations, and the model's characteristics.
The pipeline matters as much as the model. An agentic system chains retrieval, tool calls, multiple model invocations, and control logic. Optimizing the model kernel alone leaves throughput on the table, which is the entire argument for heterogeneous inference silicon.
Edge Inference Is a Different Problem, and It Is Growing
Edge AI inference runs under fixed power, area, and latency budgets, so efficiency per watt and per square millimeter decides the design. At the edge, energy efficiency is paramount, and space is limited. AI accelerator IP is therefore integrated directly into the SoC, whether the device is a smartphone or an industrial robot.
The demand is broadening fast. Physical AI applications, including autonomous vehicles, robotics, drones, industrial automation, and healthcare, are giving NPUs a more critical role. Requirements vary widely across that range. An automotive AI system may require substantial compute, whereas a low-cost consumer device is driven primarily by price and very low power. Across all of them, the silicon must now run transformer-based multimodal models and LLM-based agents alongside classic convolutional networks. The same non-matrix overhead that shapes agentic AI in the cloud now appears on the device.
Memory capacity and bandwidth are important considerations for on-device generative AI. Depending on the application and SoC architecture, edge systems may use LPDDR, DDR, and on-chip SRAM to balance memory capacity, bandwidth, power, and cost.
How to Evaluate Inference Silicon Honestly
TOPS—trillions of operations per second—is a useful capacity indicator, but it is not a complete measure of inference performance. A chip can advertise high peak TOPS while delivering poor real-world throughput if memory bandwidth, data movement, compiler quality, operator support, or utilization becomes a bottleneck. Four questions produce a better picture.
  1. What is the achieved utilization on the target model, not the peak? Ask for measured inferences per second on your own network.
  2. What is the memory bandwidth per unit of compute? For decode-dominated LLM workloads, the ratio of memory bandwidth to compute capacity is an important indicator of potential throughput.
  3. How much state fits on the device? For agentic serving, this determines how many concurrent sessions the part can hold, which determines whether batching can rescue you from the bandwidth bound.
  4. What does the software cost? An architecture requiring hand-tuned kernels per model is a research project. Framework coverage and compiler maturity determine whether the silicon is usable on the model you will be running in 18 months, which is not the model you are benchmarking today.
For power-constrained edge and embedded systems, TOPS per watt is often more informative than peak TOPS alone. It is still derived from a peak figure, so confirm the precision it assumes and check it against measured results on your own network.
For agentic AI, the practical question is not “How many TOPS does the NPU have?” It is: Can the SoC implement the full workload pipeline at the required latency and power budget?
Inference Silicon Design with Cadence
Cadence provides the AI IP for edge and physical AI subsystems, the memory IP that serves both edge and data center designs, and the multi-die design and analysis tools that bring them together.
Neo NPU: The Cadence Neo NPU IP delivers energy-efficient hardware-based AI inference acceleration that is highly scalable, easy to integrate, and architected to support legacy, current, and emerging neural networks.
Cadence Neo NPU
This flexibility enables a wide range of applications, including sensor, audio, voice/speech, vision, radar, and more. With its broad performance range, the Neo NPU is well-suited for ultra-power-sensitive applications such as IoT and hearables/wearables, as well as high-performance systems in AR/VR, automotive, robotics, and everything in between.
 NeuroEdge AICP: The NeuroEdge AICP, announced in May 2025, is part of the Cadence Tensilica family.  Cadence Tensilica NeuroEdge 130 AI Co-Processor (AICP) is a new class of processor designed to complement any neural processing unit (NPU) and enable end-to-end execution of the latest agentic and physical AI networks on advanced automotive, consumer, industrial, and mobile SoCs. Based on the proven architecture of the highly successful Tensilica Vision DSP family, the NeuroEdge 130 AICP delivers more than 30% area savings and over 20% savings in dynamic power and energy without impacting performance. It also leverages the same software, AI compilers, libraries, and frameworks to deliver faster time to market. Multiple customer engagements are currently underway, and customer interest is strong.
NeuroWeave SDK: The Cadence NeuroWeave SDK provides a common software development environment for deploying and optimizing neural networks across Cadence AI IP. Its compiler infrastructure supports model import, quantization, graph optimization, workload mapping, and heterogeneous compute offloading. These capabilities help SoC developers optimize models for target hardware while managing performance, accuracy, and power requirements.
Memory Interface and Storage IP: Memory architecture is a critical part of AI silicon design, influencing the movement of model weights, activations, and intermediate data between processing elements and memory. Cadence Memory and Storage IP solutions support a broad range of industry standards with controller and PHY implementations for both high-performance and low-power applications.
Take advantage of widely used memory and storage protocols including the latest DDR, LPDDR, GDDR, HBM, NAND Flash, xSPI, and SD/eMMC standards. Robust hard PHYs are backed by complete characterization reports for high-performance apps, while firm PHY options provide flexibility.
Multi-Die 3D-IC Solution: Advanced AI SoCs increasingly rely on complex architectures, including chiplets and multi-die integration. Cadence's Multi-Die 3D-IC Solution supports the design and analysis of these systems, including power integrity, signal integrity (SI/PI), thermal behavior, and timing. These capabilities help designers evaluate the interactions between compute, memory, and interconnect in advanced AI silicon. It provides end-to-end support for critical domains, including static timing, electromagnetic interference (EMI), thermal analysis, and co-design across custom analog, IC, and board design. Additionally, the platform supports photonics integration, enabling advanced designs for optical and optoelectronic systems.
FAQs
What hardware does agentic AI need?
Agentic AI needs inference silicon with enough memory capacity and bandwidth to hold and stream a large KV cache, efficient low-precision arithmetic, and the flexibility to run non-matrix operations across a multi-step pipeline. In the data center, that is primarily a question of accelerator memory systems and interconnect. On edge and physical AI devices, it typically means a heterogeneous subsystem: an NPU, an AICP, and a memory system sized to the context the agent must sustain.
What is inference optimization?
Inference optimization is the set of hardware and software techniques that reduce the latency, energy, and memory traffic of running a trained model. Common techniques include quantization, compiler-level graph optimization, offloading non-MAC operators to an AICP, data compression, and KV caching.
What is edge AI, and why run inference on the device?
Edge AI means running AI models directly on devices, such as vehicles, cameras, robots, or phones, rather than in a remote data center. Cloud-based inference adds latency and power overhead because data must travel between the device and the server. On-device inference removes that round trip, which matters for applications that must respond in real time.
What is the difference between AI training and AI inference hardware?
Training adjusts a model's weights using large datasets and runs mainly in the data center. Inference runs the finished model to produce outputs, both in the data center and on edge devices. Memory choices often follow that split: Data center accelerators commonly use HBM, while edge devices typically rely on LPDDR-class memory.
