  3. Meet InnoStack AI Super Agent
Reela Samuel
Reela Samuel
agentic ai
Digital Implementation
Innovus
signoff
AI/ML
Super Agents
11 Nov 2026 • 8 minute read
The Cadence InnoStack AI Super Agent brings agentic orchestration to digital implementation and signoff, helping engineering teams explore design alternatives, coordinate workflows, and make informed PPA tradeoffs. In an advanced-node SoC design collaboration, the InnoStack AI Super Agent is targeting up to a 2X improvement in design turnaround time.
Innostack AI Super Agent
Digital implementation involves a series of interdependent engineering decisions. A change to macro placement can affect congestion and timing, while adjustments to placement density or routing constraints can introduce new tradeoffs in power, performance, and area (PPA). Engineers must evaluate these effects across implementation and signoff, often running multiple experiments before identifying an approach that meets the design objectives.
Managing these experiments requires engineers to coordinate activities across synthesis, floorplanning, physical implementation, and signoff, while assessing how changes at one stage affect subsequent stages. As design complexity increases, this places additional demands on engineering time and decision-making.
The Cadence InnoStack AI Super Agent applies agentic AI to digital implementation and signoff. It brings together specialized AI agents that interpret engineering objectives, coordinate implementation tasks, explore design alternatives in parallel, and analyze intermediate results using Cadence EDA tools.
This allows engineers to investigate multiple implementation options, assess PPA tradeoffs, and determine subsequent actions while retaining control over engineering decisions and final design signoff.
Agentic AI for Digital Implementation and Signoff
The InnoStack AI Super Agent is a domain-specific AI super agent for digital chip implementation and signoff. Its scope spans RTL optimization, floorplanning, physical implementation, signoff analysis, engineering change orders (ECOs), and multi-die planning.
An engineer can provide a high-level objective, such as investigating a timing issue or exploring floorplan alternatives. The InnoStack  AI Super Agent breaks that objective into tool-specific tasks and assigns work to specialized agents. These agents interact with Cadence EDA tools, interpret logs and analysis results, and use the findings to inform subsequent steps.
Engineers can also use a natural-language interface to query design information, investigate implementation issues, and debug problems. They can review the results, refine objectives, and make decisions that require engineering judgment.
Five Areas of Digital Implementation and Signoff
The system supports five areas of digital implementation and signoff, each involving different engineering decisions and Cadence technologies.
1. RTL Optimization: Improve Implementation Readiness
RTL and synthesis constraints influence the quality of the resulting implementation. Changes at this stage can affect downstream power, performance, and area, as well as the effort required during physical implementation.
Specialized agents work with Genus Synthesis Solution and Innovus+ Synthesis and Implementation System to optimize RTL and synthesis constraints. Engineers can assess how these changes affect downstream implementation and identify options that better align with the design's PPA objectives.
2. Floorplanning: Explore Alternative Design Options
Macro placement, floorplan dimensions, and placement density all influence congestion, routability, and timing. A floorplan that looks suitable at an early stage may introduce problems when the design moves into placement and routing.
Using the Innovus+ System, the AI Super Agent can generate and assess alternative floorplans. Engineers can examine different macro placements and floorplan configurations, comparing their effects on congestion, routability, and implementation feasibility before proceeding with a preferred option.
3. Physical Implementation: Coordinate Placement, Clocking, and Routing
Placement, clock tree synthesis, routing, and physical optimization are closely related. For example, changes made to resolve congestion can affect timing, while timing improvements may introduce new routing or physical design constraints.
Innovus+ provides the implementation environment for these activities. Specialized agents coordinate the relevant tasks, examine intermediate results, and investigate alternatives. The Tempus Timing Solution contributes static timing analysis, helping engineers assess timing effects and inform timing-aware optimization.
Rather than treating each implementation issue in isolation, the agents can use intermediate results to inform subsequent experiments. Engineers can then compare the resulting options without having to initiate and manage every experiment individually.
4. Signoff and ECO: Analyze Issues and Support Closure
Signoff analysis identifies whether an implementation meets its timing, power-integrity, and physical verification requirements. When a violation or other issue appears, engineers must identify its cause, determine a suitable corrective action, and check whether that change introduces problems elsewhere.
The InnoStack AI Super Agent brings together specialized agents and Cadence technologies to support this process:
  • Tempus Timing Solution: Performs static timing analysis and supports timing signoff.
  • Voltus IC Power Integrity Solution: Provides power-integrity analysis, including IR-drop analysis.
  • Pegasus Physical Verification System: Supports physical verification and signoff.
  • Conformal AI Studio: Provides logical-equivalence checking and AI-assisted signoff capabilities.
The agents can examine analysis results, help identify potential corrective actions, and support ECO-related work. Engineers remain responsible for reviewing the changes and determining whether the resulting design meets signoff requirements.
5. Multi-Die Planning: Extend Optimization to Advanced Architectures
Chiplet-based designs and 3D-IC integration introduce considerations that extend beyond an individual die. Planning must account for chiplet organization, interactions between dies, and system-level design requirements.
Through the Integrity 3D-IC Platform, the AI Super Agent extends its scope to multi-die planning, including chiplet planning, system-level analysis, and 3D-IC closure considerations.
A More Coordinated Approach to Implementation
Conventional implementation already involves iterative optimization, concurrent analysis, and exploration of design alternatives. Engineers coordinate the tools, review results, adjust constraints, and decide which experiments to run next.
InnoStack Agent Coordination
The InnoStack AI Super Agent adds an agent-coordination layer to the implementation workflow. Specialized agents coordinate related tasks, analyze intermediate results, and use those findings to determine subsequent actions, reducing the need for engineers to initiate and review every experiment individually.
Engineers can then compare the alternatives and decide which implementation direction best meets the design objectives.
Three elements support this operating model.
Parallel Exploration of Design Alternatives
Evaluating different combinations of constraints, floorplans, and optimization strategies can involve many experiments. The InnoStack AI Super Agent can coordinate multiple experiments in parallel, allowing specialized agents to investigate different options and assess their implications for PPA and implementation convergence.
This gives engineers a broader set of results to compare without manually initiating and tracking every experiment.
AI Reasoning Grounded in Engineering Analysis
AI models help interpret engineering objectives, plan tasks, coordinate agents, and make sense of intermediate results. However, AI-generated recommendations must be validated through engineering analysis to determine whether proposed changes meet design requirements for timing, power, area, and other implementation constraints.
The AI Super Agent invokes Cadence's physics-based EDA technologies and deterministic solvers to perform the underlying engineering analyses. The resulting measurements and verification results provide the basis for evaluating candidate implementations against design objectives.
Maintaining Design Context Across Tasks
An agent working on one part of a design needs relevant information about the broader design, including specifications, constraints, libraries, hierarchy, and connectivity. Cadence's agentic AI architecture brings together three components to support this.
Cadence's newly announced provides domain-specialized models that power its AI Super Agents, including the Cadence InnoStack AI Super Agent, supporting engineering reasoning and decision-making across complex design workflows.
Mental models maintain shared design information, including specifications, diagrams, libraries, hierarchy, connectivity, constraints, and workflow history.
Cadence Native Skills help agents interact with Cadence tools and interpret their outputs.
These components help agents maintain consistent design information as they move between tasks, reducing the risk of treating each engineering activity as an isolated problem.
Applying Agentic AI to Implementation Challenges
Consider an engineer investigating high congestion near a memory macro after initial placement. Timing analysis also identifies negative slack on paths crossing the same region. Since the two issues may be related, addressing them requires evaluating their combined impact rather than changing an individual placement constraint.
The engineer can ask the InnoStack AI Super Agent to investigate the relationship between the two issues and explore alternative floorplans. Possible options include adjusting macro placement, widening routing channels, or modifying placement density around the affected region.
The InnoStack AI Super Agent can coordinate parallel implementation experiments in Innovus+ to assess these alternatives. Tempus Timing Solution provides timing analysis, while Voltus IC Power Integrity Solution contributes power-integrity analysis. The resulting data helps engineers compare the alternatives in terms of congestion, timing, power, and area.
The engineer can review the results, compare the tradeoffs, and select a preferred implementation. The InnoStack AI Super Agent can then be directed to continue with subsequent implementation activities or support ECO closure.
For experienced engineers, this means more time can be spent assessing complex design decisions rather than manually managing each experiment. Engineering managers can also gain a clearer view of the alternatives being investigated and how engineering effort is being allocated across implementation challenges.
Advancing Agentic AI for Advanced SoC Design
Cadence is collaborating with a leading semiconductor manufacturer to integrate its agentic AI capabilities into an advanced-node SoC design platform. The integration is intended to support agentic design orchestration across key SoC workflows, from early architectural exploration through implementation and signoff. As part of the collaboration, the company is targeting up to a 2X improvement in design turnaround time compared with traditional flows.
Frequently Asked Questions
  1. What is the InnoStack AI Super Agent?
    The Cadence InnoStack AI Super Agent is an agentic AI system for digital chip implementation and signoff. It coordinates specialized agents across RTL optimization, floorplanning, physical implementation, signoff analysis, ECOs, and multi-die planning, using Cadence EDA technologies.
  2. How does the InnoStack AI Super Agent help improve PPA?
    It helps engineers investigate alternatives in RTL, synthesis constraints, floorplanning, and physical implementation. Cadence EDA tools analyze the resulting candidates, allowing engineers to compare their power, performance, and area characteristics.
  3. How does the InnoStack AI Super Agent combine AI agents with EDA tools?
    Specialized AI agents interpret engineering objectives, coordinate tasks, and assess intermediate results. When engineering analysis is required, they invoke Cadence EDA tools and deterministic solvers to evaluate candidate implementations against design objectives.
  4. How is the InnoStack AI Super Agent different from conventional digital implementation workflows?
    Conventional workflows rely on engineers to coordinate tools, review results, adjust constraints, and manage iterations. The InnoStack AI Super Agent adds an agent-coordinated layer that can manage related experiments, explore alternatives in parallel, and use intermediate results to inform subsequent actions. Engineers continue to review the results and make the decisions that determine the implementation direction.
Bringing Agentic Intelligence to Digital Implementation
Digital implementation requires engineers to balance decisions across synthesis, floorplanning, physical implementation, and signoff. The InnoStack AI Super Agent adds an agent-coordinated layer to this process, helping engineers investigate alternatives and assess their effects across design objectives while retaining responsibility for implementation decisions and signoff.
Explore how InnoStack AI Super Agent can support your digital implementation and signoff workflows.
