  3. Meet ViraStack AI Super Agent: Bringing Agentic AI to Custom…
Reela Samuel
Reela Samuel
agentic ai
AI in chip design
Mental Model
AI Super Agents
analog design
AI/ML
Custom IC
Meet ViraStack AI Super Agent: Bringing Agentic AI to Custom and Analog Design
19 Nov 2026 • 9 minute read
The ViraStack AI Super Agent brings specialized AI capabilities to custom and analog IC design, working alongside engineers in the Virtuoso environment. From IP reuse and circuit creation to simulation, debugging, optimization, and design migration, it supports key stages of the design workflow. By combining Cadence's mental model, specialized agents, and native skills, it brings design context and engineering knowledge into AI-assisted tasks. The result is more efficient workflows, greater reuse of engineering expertise, and improved productivity for design teams.
Custom and analog IC design requires engineers to balance multiple, interdependent circuit parameters while meeting stringent performance, power, and area requirements. Transistor sizing, gain, bandwidth, noise, stability, and power consumption all influence circuit behavior. As designs progress from schematic to layout, parasitics, device matching, and physical effects introduce additional considerations that must be evaluated.
The process involves repeated cycles of design creation, simulation, analysis, debugging, and optimization. Design migration across process technologies adds another layer of complexity, requiring engineers to account for changes in device characteristics and process-specific constraints.
The ViraStack AI Super Agent, paired with Virtuoso AI Studio, brings specialized AI capabilities to these custom and analog design activities. It supports workflows spanning design creation, IP reuse, simulation, optimization, debugging, and migration, while keeping engineers involved in technical decisions and design validation.
Here are some examples of how engineers can apply the ViraStack AI Super Agent to common custom and analog design tasks.
Start with Existing Design Knowledge and Reusable IP
A new design does not always need to begin from scratch. Organizations often have libraries of proven analog building blocks, previous designs, specifications, and engineering documentation that can inform new projects. Finding the right information and determining whether an existing design is suitable for reuse, however, can take considerable time.
The ViraStack AI Super Agent helps engineers levergae this existing design knowledge through the IP catalog and mental model. The IP catalog provides access to reusable design assets, including analog building blocks. Engineers can use natural-language interaction to explore available IP and identify relevant starting points for a design. Reusing proven design elements can reduce duplicated effort and help teams build on established engineering work.
Mental model provide a complementary layer of design context. They are knowledge graphs that bring together information from existing design data, specifications, diagrams, libraries, and other human-readable sources. Rather than treating these materials as disconnected references, mental model organize the information into a structured representation of the design and its intent.
For custom and analog design, this context can include circuit functionality, topology, specifications, hierarchy, relationships between design elements, layout intent, process design kit (PDK) information, tool context, and engineering constraints. The ViraStack AI Super Agent uses mental model as a source of design knowledge when interpreting requests and working through design tasks.
This matters because an instruction such as optimizing an amplifier cannot be considered in isolation. The agent needs to work within the context of the circuit, its intended behavior, and the constraints that define an acceptable result. Mental model help provide that context.
For engineering teams, this approach also makes existing design knowledge more accessible and reusable. It can help reduce dependence on individuals who may be the only people familiar with a particular design or its history.
Create and Modify Designs Using Natural Language
Custom design work often involves translating specifications and design intent into circuit structures, configuring parameters, and refining implementations. Engineers can use the ViraStack AI Super Agent to interact with design tasks through natural-language requests, supported by the context available through mental model and Virtuoso AI Studio.
For example, an engineer working on an analog block can describe the intended functionality and requirements. The ViraStack AI Super Agent can assist with identifying relevant design information, creating or modifying design elements, and supporting the next steps in the workflow.
This interaction is not simply a matter of generating circuit code from a prompt. The design task needs to account for the topology, device characteristics, specifications, and constraints that influence circuit behavior. The ViraStack AI Super Agent brings together design context and specialized capabilities to support that work.
Engineers can also use AI skills to capture and reuse task-specific knowledge. These skills can support repeatable activities, such as generating SKILL code or carrying out recurring design operations. Reusable skills can help teams apply established methods more consistently across projects, while allowing engineers to adapt them to the requirements of individual designs.
Configure Testbenches and Investigate Simulation Results
Simulation is central to analog design. Engineers need to configure testbenches, select appropriate analyses, define measurements, interpret results, and determine whether a circuit meets its specifications.
The ViraStack AI Super Agent can assist with testbench configuration and simulation-related tasks through Virtuoso AI Studio. Engineers can describe the analyses and measurements they need, and the agent can help configure the corresponding simulation workflow.
Consider an amplifier characterization task. An engineer may need to evaluate open-loop gain, bandwidth, and phase margin. The ViraStack AI Super Agent can assist in configuring the testbench and setting up the required analyses and measurements.
If the simulation indicates that the amplifier does not meet its bandwidth target, the engineer can use the agent to investigate the result. The agent can help examine possible causes and suggest changes, such as adjustments to transistor sizing. The engineer can then evaluate the effect of those changes on bandwidth and other circuit requirements.
This is important because improving one parameter does not necessarily improve the overall design. Increasing bandwidth, for instance, may affect gain, power consumption, noise, or stability. Engineers must assess these trade-offs against the complete set of specifications before accepting a proposed change.
While the ViraStack AI Super Agent helps to shorten the time spent on testbench setup and result investigation, but the engineer remains responsible for interpreting the results and deciding whether the design meets its requirements.
Debug Testbenches and Verify Design Behavior
Simulation issues do not always originate in the circuit itself. Incorrect testbench configuration, unsuitable stimulus, measurement setup, or other verification issues can make it difficult to determine why a simulation is failing or producing unexpected results.
The ViraStack AI Super Agent supports testbench debugging and verification activities, helping engineers investigate problems and identify areas that need attention. It can assist in examining the testbench configuration, interpreting relevant information, and working through the steps needed to resolve issues.
This can be particularly useful when debugging complex testbenches or when engineers need to understand why a particular analysis is not producing the expected result. Instead of manually tracing every configuration detail, they can use natural-language interaction to guide the investigation.
The aim is not to replace engineering judgment or verification. Rather it is to help engineers move more efficiently from an observed problem to a clearer understanding of its cause, so they can focus on evaluating the circuit's behavior and making informed design decisions.
Optimize Designs Against Multiple Constraints
Analog optimization is rarely a single-variable exercise. A change that improves one performance metric may affect several others. Engineers must consider interactions among gain, bandwidth, power, noise, stability, area, and other design requirements.
The ViraStack AI Super Agent can support design centering and optimization by helping engineers explore design parameters and evaluate possible changes against specified objectives and constraints.
For example, an engineer optimizing an analog block can use the agent to investigate parameter adjustments and their potential impact on the required performance targets. The agent can help organize the exploration and support the analysis of simulation results. Engineers can then compare the alternatives and determine which changes are appropriate for the design.
This can make optimization workflows more systematic, particularly when several parameters need to be evaluated together. It also helps teams apply engineering knowledge and established methods more consistently across design tasks.
For engineering managers, repeatable optimization workflows can improve visibility into how design tasks are approached and where engineering effort is being spent. They can also help teams make better use of experienced engineers' knowledge across multiple projects, rather than relying entirely on individual, manually repeated processes.
Migrate Designs Across Process Technologies
Design migration is a demanding part of custom and analog engineering. Moving a design to another process technology involves more than translating circuit elements. Differences in device characteristics, process constraints, and operating conditions can affect circuit behavior and require changes to the original implementation.
The ViraStack AI Super Agent supports design migration by helping engineers work through migration-related tasks, interpret design context, and address the changes needed for the target process. Mental model provide relevant information about the existing design and its intent, while specialized capabilities support the migration workflow.
This is particularly valuable when teams need to preserve the intended functionality and performance of an established design while adapting it to a different technology. Engineers can use the agent to assist with evaluating and modifying the design, then validate the resulting implementation through appropriate simulation and verification activities.
In a demonstrated 6-GHz analog/RF PHY migration use case, the ViraStack AI Super Agent enabled 60% faster design closure. This illustrates the potential of applying specialized AI capabilities to a technically complex migration workflow, rather than treating migration as a generic code-generation task.
Support RF Design Workflows
RF design brings additional challenges, including high-frequency behavior, matching, parasitics, and interactions among circuit elements. These considerations make design analysis and optimization particularly dependent on accurate context and engineering expertise.
The ViraStack AI Super Agent includes specialized RF design capabilities to support tasks in this area. By bringing design context, domain-specific knowledge, and Virtuoso workflows together, it can assist engineers as they work through RF design activities and evaluate design requirements.
The broader productivity results demonstrate the potential across custom and analog design engagements. Cadence has reported 3.2X layout productivity and productivity improvements of up to 70% across more than 80 engagements spanning process technologies from 130 nm to 3 nm. These results represent different measures and use cases, rather than a single expected outcome for every design team.
What Makes the ViraStack AI Super Agent Design-Aware?
The capabilities of the ViraStack AI Super Agent come from the combination of several elements:
  • Mental model: Knowledge graphs that bring together design data, specifications, diagrams, libraries, and other sources to represent design context and intent. They provide a structured source of information that helps the agent interpret and work with a design.
  • Specialized agents: Task-oriented capabilities for activities such as design creation, migration, optimization, testbench debugging, simulation, and RF design.
  • Native skills: Domain-specific knowledge that helps large language models work with Cadence EDA tools, use relevant APIs, and interpret detailed tool traces and logs.
  • Virtuoso AI Studio integration: Connects AI-assisted interactions with custom and analog design workflows in the Virtuoso environment.
Together, these elements connect design intent, engineering knowledge, and EDA tool operations. Mental model provide the design context; specialized agents and Native Skills help translate engineering requests into relevant tasks and tool interactions.
The engineer remains central to the process. Engineers review proposed changes, assess simulation results, make design decisions, and determine whether the implementation meets the required specifications before signoff.
Bringing AI into Everyday Custom and Analog Design
The value of the ViraStack AI Super Agent is best understood through the engineering work it supports: finding and reusing IP, creating and modifying designs, configuring simulations, investigating failures, optimizing circuit behavior, and migrating designs across process technologies.
For individual engineers, this means more support across the iterative tasks involved in custom and analog design. For engineering managers and decision-makers, reusable skills, accessible design knowledge, and more consistent workflows can help teams apply expertise across projects, improve productivity, and make better use of engineering capacity.
The objective is to give engineers AI capabilities to assist with critical decision making, while preserving the technical judgment and validation that custom and analog design demand.
Explore how the ViraStack AI Super Agent, paired with Virtuoso AI Studio, can support your custom and analog design workflows.
