  3. AMICAL Project: Modeling Tools for Low-Noise Fan Techno…
Veena Parthan
Veena Parthan
CFD
AMICAL project
low-noise modeling technologies
high-order
Fidelity CFD
engineering
simulation software
Lattice boltzmann
Cadence CFD
Navier Stokes
AMICAL Project: Modeling Tools for Low-Noise Fan Technologies
1 Mar 2023 • 1 minute read
Aircraft fan blades
Low-noise fan technologies must be developed for next-generation UHBR (Ultra High By-pass Ratio) engines. The design of these innovative fan technologies is highly dependent on the capability of the modeling tools to predict the aeroacoustics phenomena in the engine while ensuring a high level of accuracy.
The AMICAL project focuses on advanced high-fidelity numerical techniques based on lattice Boltzmann and high-order Navier Stokes methods applied to industrial fan/outlet guide vane configuration to identify primary noise sources. The project will compute several fan/outlet guide vane configurations, including installation effects, noise reduction techniques, and wind tunnel experiments. The project will also focus on new post-processing techniques to improve noise source detection and comprehension.
CleanSky
Project Objectives
The AMICAL project aims at developing and validating advanced numerical tools, based on high-order and lattice Boltzmann methods, for the accurate and reliable prediction of UHBR aeroacoustic effects. A significant challenge of next-generation UHBR engines is noise reduction and it depends on high-fidelity simulation techniques at the pre-design stages. Developing innovative noise post-processing techniques is also part of the project objectives. New post-processing methodologies will be developed to exploit combined acoustic, numerical, and experimental databases to identify UHBR fan noise sources and improve the physical understanding of noise generation mechanisms.
List of Work Packages
Work Package 1: Management, dissemination, and risk reduction plan
Work Package 2: Requirements
Work Package 3: High-fidelity simulations of a UHBR Fan/OGV module
Work Package 4: High-fidelity simulations of an integrated propulsion system
Work Package 5: High-fidelity simulations in wind tunnel environments
Work Package 6: Innovative data treatments for noise source diagnostic
Work Package 7: Innovative aeroacoustics solution for antenna instrumentation
Work Package 8: Development of advanced aeroacoustics simulation abilities for noise reduction concepts
Work Package 9: High-fidelity modeling of a UHBR fan module with noise reduction concepts
The AMICAL consortium is formed by Cadence (also coordinating the project), PSA3 - a Dutch expert in noise identification and post-processing, and CERFACS, a prominent French research center. All three partners have extensive experience in EU and Cleansky projects.
Logos of project partners
If you would like to try Cadence Fidelity high-order tools for your CFD application, request a demo today!
