  3. Cadence CFD Advances Greener Turbomachinery at ASME Turbo…
Veena Parthan
Veena Parthan
propulsion
Lunch and Learn
turbomachinery
ASME Turbo Expo
Computational Fluid Dynamics
simulation software
Cadence CFD Advances Greener Turbomachinery at ASME Turbo Expo 2024
10 Jun 2024 • 3 minute read
The ASME Turbo Expo 2024 is all about propelling towards a net-zero future in propulsion and power. It will showcase the latest hydrogen technology and sustainable solutions like green energy and low-carbon fuels. This year, the focus is on evolving turbomachinery and propulsion technology for net-zero goals, highlighting disruptive technologies, sustainable ecosystems, and a collective push for innovation and sustainability.
Cadence Invites You to Booth 410
As a proud sponsor of the 69th ASME Turbo Expo, Cadence invites you to visit our booth 410.
Discover the unique and innovative products and technologies revolutionizing the turbomachinery industry. Our expert team will be there to answer any questions you may have and provide in-depth demonstrations of our cutting-edge technology. This is your exclusive chance to see the future of turbomachinery.
Date: 24th to 28th Jun
Lunch and Learn with Cadence
Don't forget about our annual Lunch & Learn event! We're excited to connect with the turbomachinery community and showcase our latest developments in CFD simulation.
At the event, we'll showcase our high-fidelity simulation tools running on the Cadence Millennium Supercomputer, offering rapid results in aerodynamics, aeroacoustics, and combustion. We're also introducing the integration of CFD workflows into the Cadence Optimality Intelligent System Explorer for comprehensive multi-disciplinary analysis and optimization.
Date: Monday, June 24
Time: 12:00 - 13:30
Register today to save your seat!
Don’t Miss Out on These Presentations!
The following papers will be presented at the ASME Turbo Expo, and the technology used in these presentations is Cadence Fidelity LES.
GPU-Accelerated Full-Wheel Large-Eddy Simulations of a Transonic Fan Stage
Session: 34-08 LES Solvers and Applications 2
Cadence CFD has harnessed advances in numerical algorithms and computer hardware to overcome the limitations of traditional high-fidelity methods such as large eddy simulation (LES). A detailed simulation of the NASA 67 single-stage transonic axial-flow fan is conducted by leveraging the Fidelity LES solver. This simulation covers the fan's operation at full speed, including the use of two mesh types with millions of control volumes and employing advanced turbulence models. The resulting performance curves agree with experimental data and represent a significant achievement in computational fluid dynamics applied to turbomachinery.
Coupled Design of Multi-Component Distortion-Generating Devices for Aircraft Engine Ground Tests
Part I: Design Methodology and Numerical Validation
Part II: Experimental Characterization in a Closed-Loop, High-Speed Test Rig
Session: 01-05 Inlet Distortion and Engine Operability I
Advanced aircraft engine configurations like Ultra High Bypass Ratio (UHBR) engines, Blended Wing Bodies (BWB), and Boundary Layer Ingestion (BLI) configurations experience significantly higher flow distortion at the fan inlet compared to current designs. This non-uniform inlet flow can drastically affect engine performance, operability, and vibration, necessitating extensive testing to assess engine-airframe incompatibilities.
The first presentation on this topic covers the development of a numerical design methodology capable of reproducing complex and realistic distortion patterns, the design of distortion devices, and the experimental validation of 3D-printed screens using computational fluid dynamics and machine learning. The second presentation focuses on testing the distortion screens in a high-speed test rig and compares the results with the design target patterns to assess the design method and identify potential improvements.
Combination of a total pressure distortion screen
Combination of a total pressure distortion screen and a swirl vanes assembly producing the flow angle distortion pattern
Large Eddy Simulation of Turbulent Reacting Flow in a Pressurized Annular Combustor
Session: 04-16 Combustion Modeling IV
Large-eddy simulations (LES) are increasingly used in engineering to predict complex physical interactions in propulsion systems with realistic combustors. This presentation aims to demonstrate LES's ability to capture turbulence, flame dynamics, and performance parameters in a realistic full-annular combustor from the Energy Efficient Engine (E3) program. The study uses the massively parallel LES solver to model turbulence-chemistry interactions and investigate the effects of grid resolution.
This work is supported by the DoD High-Performance Computing Modernization Program (HPCMP) Frontier program at ARL and NAVAIR in collaboration with the University of Cincinnati, Cascade Technologies, and Pratt & Whitney.
We look forward to seeing you at the ASME Turbo Expo 2024!
Click the button below to register your seats today.
Download the Engineer's Guide to Simulating Turbomachinery
