  3. From Concept to Aerodynamics: Simplifying Vehicle Design…
Veena Parthan
Veena Parthan
CFD
Automotive
AutoSeal
ANSA
Fidelity CFD
simulation software
Aerodynamics
meta
From Concept to Aerodynamics: Simplifying Vehicle Design with Cadence CFD
17 Nov 2026 • 4 minute read
In automotive design schools, vehicle development often starts with a story or a brief. Students translate this vision into a compelling concept, then explore how its aerodynamic behavior aligns with the design objectives. Bringing simulation into the process makes aerodynamic evidence part of design exploration, rather than a separate exercise.
Cadence handles geometry preparation, meshing, solver setup, simulation, and post-processing through the integrated ANSA–AutoSeal–Fidelity Flow–META workflow. For students and educators who are not CFD specialists, the benefit is straightforward: share the vehicle geometry, agree on a timeline, and receive a complete aerodynamic analysis while staying focused on design. Rather than managing the simulation process themselves, students and educators can concentrate on developing their concepts and using the delivered results to guide design decisions.
Dr.-Ing. Gustavo Estrada, university lecturer in aerodynamics for transportation design at Pforzheim University in Germany, highlighted this approach in his presentation, “Embedding Aerodynamic Thinking in Contemporary Transportation Design Curricula,” at the Advanced Aerodynamic Conference, held at the Catesby Innovation Centre on September 16, 2026.
Cadence Connects Vehicle Concept to Aerodynamic Evidence
For the project presented, students were tasked with designing an SUV for a race series and using aerodynamic CFD analysis to evaluate and refine their concepts. Cadence supported the project with its integrated ANSA–AutoSeal–Fidelity Flow–META workflow, enabling a seamless process from geometry preparation and simulation to post-processing and aerodynamic assessment.
For schools whose primary focus is designing vehicles around a narrative or brief, this connected process provides a practical bridge between shaping a concept and evaluating it. Students can use aerodynamic results to question their design choices while keeping the brief—not the simulation process itself—at the center of the exercise.
Share the Geometry, Let the Workflow Handle the Setup
Geometry preparation began with the Cadence BETA CAE ANSA Pre-Processor. This included defining parts and cleaning disconnected surfaces, while AutoSeal automatically closed holes and gaps. These steps addressed the practical requirements of preparing a design model for CFD simulation, connecting the geometry created to express the design intent with the model needed to study its aerodynamic behavior.
Vehicle geometry preparation establishes the model used for aerodynamic study
AutoSeal closes gaps and openings as part of preparing the geometry for simulation
The mesh was generated with Hextreme in ANSA. It comprised 65 million hexa-dominant cells, with local refinement down to 1 mm around the aerodynamic components. Automatic surface refinements were applied to capture curvature, sharp edges, and proximity between close components. Offset size fields were used to refine the wake of the vehicle.
The steady-state simulation was performed using the shear stress transport (SST) turbulence model in the coupled Fidelity Flow Solver, with rotating wheel surfaces and porous-media models for the intercooler and water cooler.
The 65-million-cell mesh represents the vehicle and its aerodynamic components
Local mesh detail around features such as the wing, mirror, wheel region, and diffuser
Section views show the distribution of mesh refinement around the vehicle
Turning Simulation Results into Design Questions
For students working from a design brief, the next step was to understand what the numerical results meant for the concept. Using the Cadence BETA CAE META Post-Processor, the whole-car analysis examined pressure distribution, surface oil-flow patterns, total-pressure structures, 3D streamlines, and the wake. These visualizations helped students investigate airflow paths, identify flow separation, and understand how different parts of the vehicle interact—turning simulation output into questions that could inform the next design decision.
Surface oil-flow visualization enables flow-path analysis with pressure coloring
3D streamlines allow tracking of the flow that goes through the heat exchangers.
The wake visualization extends the analysis beyond the vehicle’s surfaces to the downstream flow
The component-level study examined cooling flows, dive planes, louvers, front and rear diffusers, wheel regions, engine-bay exits, and the rear wing. Looking at these features individually and in the context of the whole vehicle helped connect detailed geometry with the overall aerodynamic picture.
Detailed analysis examines the interaction between the front-wheel region, louvers, and surrounding bodywork
Learning to Search for the Right Design, Not Just a New Shape
The workflow can be fully scripted and reused in subsequent studies to evaluate geometric changes. Students can propose a modification in response to the brief, analyze its effects, and compare the results with the previous configuration. An integrated CFD workflow enables them to make simulation a supporting part of the design loop. Interpreting the evidence and deciding what to change remain essential learning tasks.
For design-led curricula, the opportunity is not simply to generate another vehicle shape. It is to help students test whether a design choice advances the objectives defined in the narrative or brief. Connecting preparation, simulation, and post-processing gives them a consistent route from a proposed concept to evidence that can inform its refinement.
Building a Design Practice That Carries Forward
For automotive design schools, an accessible, end-to-end CFD solution can embed aerodynamic assessment into everyday learning. Cadence connects model preparation, flow simulation, and results interpretation, so non-specialists can simply share a geometry, receive high-quality results within the agreed timeline, and use them to judge how well each design iteration meets the original brief and decide on the next geometric change.
Focus on vehicle design. Let Cadence handle the aerodynamic analysis. The integrated ANSA–AutoSeal–Fidelity Flow–META workflow quickly turns a shared geometry into aerodynamic results, so every concept can be checked against its brief. Read the technical brief.
