  3. Masten Space Systems: Reactive Flow and Heat Transfer Optimization…
AnneMarie S
AnneMarie S
CFD
CFD Applications
Masten Space Systems: Reactive Flow and Heat Transfer Optimization for Reusable Spacecraft
27 Feb 2020 • 4 minute read
Authors: Allan Grosvenor, Aerodynamics Lead, Masten Space Systems, USA - Jean-Charles Bonaccorsi, Technical Director, NUMECA USA - Jan Anker, Head of Combustion Modeling Group, NUMECA International
Masten's reusable rocket technology
Masten Space Systems is a private company founded in 2004 and headquartered in Mojave, California, USA, by David Masten. Masten’s focus on reusable rocket technology is driven by the goal of enabling space transportation and reliable planetary landers for the Earth, Moon, Mars, and beyond.
One of Masten's recent pioneering space flight vehicle projects was to design a reusable aircraft designed to fly to the edge of space, the XS-1. The XS-1 aircraft will be capable of launching a 3,000-pound spacecraft to the earth’s orbit at a cost of $5M, which is ten times less than today’s launch systems. A key objective of the program is to fly the XS-1 10 times in 10 days in order to demonstrate its “aircraft-like” operability, cost efficiency, and reliability. Key anticipated characteristics of the aircraft include a physical size and dry weight typical of today’s business jets.
One of the new innovations in this effort is a full-scale additively manufactured aluminum thrust chamber assembly for the 25,000 lbf LOX/LCH4 dual expander propulsion system. The dual expander cycle offers an ideal cycle in this size range, enabling reusability, optimal closed-loop performance, and cost effective-design and production price points.
CFD for the Simulation, Analysis, and Optimization of Critical Spacecraft Components
Masten Space Systems is using OMNIS/Open-DBS with OpenLabs, NUMECA’s unstructured multi-purpose CFD solver package, for the design and analysis of various elements of reusable spacecraft and lunar vehicles for the testing of thrust chambers. In this article, we talk about the numerical studies of three of their aeronautical configurations.
Simulation of Plume Impingement and Thermal Load
For the testing of thrust chambers, Masten Space Systems had to determine the temperature on the impingement plate in order to avoid reaching critically high temperatures. To do this, they simulated the impact of a hot plume at multiple times the speed of sound and a temperature hotter than the melting temperature of steel on a plate by using an inert multi-species approach. The results are shown in Figure 1 below, comparing the live fire test of the plume impingement in the photograph with the predicted temperature simulated by CFD. There is a clear qualitative agreement between the two.
Comparison of a photograph and the simulated static temperature
Injector Study
For the optimization of spacecraft it is important to clearly understand the conditions of the injectors, combustion chamber and nozzle of the rocket engine. One of the critical points for example is that the walls cannot be subject to excessive thermal stress.
To analyze the combustion process and heat transfer in a generic injector configuration, a CFD study was carried out using a reactive multi-species simulation approach with a reduced chemical mechanism.
Figure 2 beside shows the injector geometry, consisting of two concentric pipes connected to a rectangular chamber. Via the inner tube Gaseous Oxygen (GOX) is injected, whereas Gaseous Methane (GCH4) is injected around it via the outer pipe. The purpose of the chamber is to create a recirculation zone, preventing the flame from blowing out. The recirculation of hot combustion products ensures a stable continuous combustion process after the engine is fired.
 Injector geometry
Two grids were generated: one coarse mesh at 1.8 million cells and one refined mesh containing 2.4 million cells with cylindrical viscous layers as shown in Figure 3.
 Injector computational grid
The simulation results were in good agreement with the measurement data. Figure 4 below shows the simulated temperature field and a comparison between the simulated and experimental values of the static pressure and heat flux.
 Predicted injector flame temperatures
Optimization of the Cooling Channel of the Combustion Chamber and Nozzle of a Rocket Engine
To evaluate the potential of optimizing the cooling channel, a generic test model was constructed with 180 cooling channels. In the baseline design, the cooling channel has an Aspect Ratio (AT) of 4.
Figure 5 below displays their total pressure, heat flux and Thermal Barrier Coating (TBC), temperature predictions.
Three sample channel geometries
These three designs all included contractions of the CH4 channel in the vicinity of the nozzle throat and then an opening up of the passage down stream. On one hand this structure appeared to accelerate the channel flow in the throat region, resulting in higher heat flux, and therefore greater cooling in that area, and maintain attached flow downstream. On the other hand, the opening up of the channel downstream appeared to reduce total pressure losses compared to the reference design.
The uniform aspect ratio baseline (ID 0) produced the lowest total pressure loss by not accelerating the channel flow anywhere, but it subsequently demonstrated the lowest cooling performance. In the search for an optimized design, Self Organizing Maps (SOM) were used to cluster the different samples in a space, such that high-dimension space data can be visualized in 2D maps and identify the design that leads to the best compromise between cooling efficiency and pressure drop in the cooling channels. By using SOMs the design IDs 184, 227, and 258 were singled out as the ones having the most promising characteristics.
