  3. Masten Space Systems: Reuseable Space Craft Innovation With…
AnneMarie S
AnneMarie S
Masten Space Systems: Reuseable Space Craft Innovation With Cadence CFD Software
16 Sep 2016 • 5 minute read
Until very recently, rockets that launched satellites into orbit were completely discarded after a single use -and this is still commonly done for most launches. Within the past year, first-generation reusable satellite launch has been demonstrated, and the business case for reusable launch has been made.
As a prime contractor for the Defense Advanced Research Projects Agency (DARPA) Experimental Spaceplane (XS-1) program, Masten Space Systems is developing a launch vehicle with design innovations focused on next-generation reusability. DARPA’s XS-1 program aims to reduce the time to space and cost to space by orders of magnitude by achieving aircraft-like reusability and flight rate [1]. Jess Sponable, DARPA XS-1 program manager, has stated: “We think flying ten times in 10 days is something well beyond the capability of either SpaceX or Blue Origin at this time.” [2]
Artistic rendering of Masten’s Xephyr post upper-stage-separation, before returning to land. | Courtesy of Masten Space Systems.
"Masten Space Systems heavily utilized the FINE (now Omnis) Suite at HPC scale to design our next-generation reusable satellite launch system. We developed an aerodynamic configuration that hasn't been done before for launch or reentry. First wind tunnel tests confirmed critical aspects of the design, and predictions compared well with measurements." --Allan Grosvenor, Aerodynamics Lead at Masten Space Systems.
Requirements include cost per flight of less than $5 million USD transporting 3,000 lbs to a 100 nmi reference orbit inclined 90 degrees. Masten engineers needed to optimize the booster design over a wide range of flight conditions, including ascent from sea level to hypersonic speeds at the upper-stage-separation point, and then reentry and return flight.
Cadence CFD has worked closely with Masten Aerodynamics Lead, Allan Grosvenor, and his team to develop an HPC-driven workflow that enables concept development, evolution, and optimization, of vehicle configuration that takes into consideration aerodynamic performance, control, loads and aerothermal heating, with simultaneous trajectory optimization.
A study of the HIFiRE-1 high speed transition experiment was one of several test cases used to validate Cadence CFD solver predictions (Figure 1). The HIFiRE-1 experiment (Wadhams, et. al. 2008) is a Cone-Cylinder-Flare configuration, exposed to Mach 7.2 flow (Re 1E7) conducted at the CUBRC LENS hypersonic tunnel. The numerical results are shown to capture relevant physics and to predict pressures and heat fluxes, and particularly the peak heating which is critical to thermal protection system design.
Figure 1. Above: HIFiRE-1 experimental rig. Below: Comparison of Omnis Turbo CFD solution vs. experimental data [4]. | Courtesy of Allan Grosvenor, Masten Aerodynamics Lead
To illustrate the optimization process we created a fictitious high speed flight vehicle test case inspired by the Colonial Viper fighter craft of the TV series Battlestar Galactica.
The ship design is controlled parametrically with Cadence's AutoBlade modeler. A set of parameters control the canopy's length and height, the wing and vertical stabilizer angle and sweepback, and the nose radius and droop (Figure 2). Extensive sets of parameters are available for more detailed 3D shaping and variation of all portions of fuselage, lifting and control surfaces, etc.
Figure 2. Parametric design variations controlled with AutoBlade
Design necessarily required consideration of entire launch and return trajectories. Large numbers of organized studies conducted by Masten Space Systems included running sweeps through several critical flight conditions including variation of flight angles (e.g., pitch, yaw, roll) and aerodynamic control surface angles. The example shown here illustrates a subset of these studies focused on reentry.
DoDHPCMP supercomputers [3] were leveraged to conduct the extensive studies, and the Computational Pipeline (Figure 3) indicates the organized workflow that was executed to run the sophisticated design evolution process. Masten Space Systems found that only with Cadence could they systematically produce high-quality grids (flow domain discretization) and high accuracy solutions.
Figure 3. HPC computational pipeline. | Courtesy of Masten Space Systems
The meshing task was automated with Omnis Hexpress, which is the new generation multi-core meshing tool of Cadence. It has been designed to generate meshes of complex geometries, regardless of the CAD format and quality (Figure 4).
Figure 4. Comparison of standard meshing practices vs. Cadence's efficient approach.
This tool produces full hexahedral and hex-dominant meshes completely in parallel and in batch mode, which has been the perfect match for Masten's challenge. Masten Space Systems chose to utilize the option producing pure hex meshes.
Figure 5. CFD grid views of the Colonial Viper model. | Courtesy of Masten Space Systems
The CFD simulations were all executed with Cadence's Omnis Open-DBS CFD solver, and then post-processed through scripts running all in batch in a fully automatic way. Data-mining of the full 3D solutions feeds the optimization process.
The following animations are comparisons between the baseline vehicle and the new design for reentry performance and stability.
Figure 6. Reentry Matrix Results Comparison: Baseline (left) vs Modified (right) designs
Figure 7. Performance and stability plots showing how optimized design is significantly better than baseline model. | Courtesy of Masten Space Systems
For more information about Cadence software products and consulting services, please visit our website or call +1(415)558-8483.
Mentioned in This Article
Masten Space Systems lowering the barriers to space access. Their mission contributes to a shared strategic goal of extending human presence across the solar system. Their approach: reusability. Their technology development focuses at the core on entry, descent, and landing technologies (EDL) to ensure precise and safe landings on planets and other celestial bodies. Learn more
Cadence CFD​ is a pivotal leader in electronic design, building upon more than 30 years of computational software expertise and decades of computational fluid dynamics (CFD) expertise. With an industry-leading meshing approach and a robust host of solver and post-processing capabilities, Cadence CFD provides a comprehensive workflow for applications including propulsion, aerodynamics, hydrodynamics, and combustion. Learn more.
  • DARPA pushing new effort with Experimental Spaceplane, XS-1 (nasaspaceflight.com)
  • DARPA experimental spaceplane program moves into next phase (spacenews.com)
  • Supercomputers Lower the Cost of Space Access (digitaleng.news)
  • HIFiRE-1 Mach 7 aerothermal heating prediction (researchgate.net)
