  3. New Release - Omnis Version 5.1 Is Out Now!
AnneMarie S
AnneMarie S
CFD
Computational Fluid Dynamics
Omnis
22 Jun 2021 • 2 minute read
Want to see it in action?
VIEW WEBINAR RECORDING
The newest version of the OmnisTm simulation environment brings a new discrete particle solver, a surface-to-volume mesh module and more than 100 other new features that will simplify your workflows, boost your productivity and extend the scope of your simulations.
Omnis/Hexpress – Surface to volume meshing approach
Omnis/Hexpress extends its unstructured mesh generation tool set with the surface-to-volume module.
The surface-to-volume module allows generating 3D grids with high-quality surface meshes, aligned with the geometry and with smooth and thickness-controlled viscous layers when the geometry is clean and conformal.
 Omnis Hexpress CFD mesh generation
Omnis/Autogrid - Meridional effects with autoblocking (beta)
Omnis/AutoGrid can now generate multi-block structured meshes of axisymmetric meridional effects (e.g. seal leakage, bleed or cavities) connected to the channel of the turbomachinery configuration.
 Omnis Autogrid multiblock structured CFD meshes
Omnis/Turbo – Coarse grid simulation
The Omnis/Turbo simulation can run on a coarser grid level with the same mesh and simulation setup. This feature allows to quickly assess the correct setup of the simulation and preview its results before a final accurate run on the finest grid level.
 Course CFD grid simulation with Omnis Turbo
Omnis/Open (DBS and PBS) – Surface-to-surface radiation
The surface-to-surface (S2S) radiation model has been introduced in the Omnis/Open density-based and coupled pressure-based solvers to account for the radiation exchange in an enclosure of grey-diffuse surfaces.
 Surface-to-surface radiation CFD simulation with Omnis
Omnis/Oofelie – Advanced thermomechanical analysis for turbomachinery
Our commitment to providing more advanced solutions for turbomachinery designers continues with OmnisTm/Oofelie. The results of static runs can be used for calculating natural frequencies and mode shapes of mechanical parts. Other important new features include also the computation of complex mode shapes due to the presence of Coriolis effects and wet mode shapes, for machines with a high-density operating fluid.
 Omnis Oofelie thermomechanical CFD analysis for turbomachinery
Omnis/Mpacts – Particles motion and interaction (beta)
The new Omnis/Mpacts solver allows the simulation of particle collisions for a variety of industrial applications such as conveyor belts, hoppers and mixers.
Omnis/Mpacts combines the power of the advanced Discrete Element Method (DEM) solver Mpacts with the user-friendly OmnisTm interface and all its capabilities from the pre-processing to co/post-processing in one workflow.
 Omnis Mpacts particle motion and interaction CFD simulation
Omnis/Post – Display streamlines
Users can now display streamlines to trace the flow velocity, from a point, line, plane, or sphere with interactive controls in Omnis/Post.
 Omnis Post display streamlines CFD simulation to trace flow velocity
And plenty of other improvements have been made, details are available on our customer area.
We hope you enjoy this new version!
