  3. Not-to-miss Live Webinars about CFD This Month
AnneMarie S
AnneMarie S
CFD
webinars
Pointwise
Computational Fluid Dynamics
fluid dynamics
CFD Applications
NUMECA
Mesh Generation
Meshing
Omnis
10 Jun 2021 • 2 minute read
In June once more we launch a series of not-to-miss live webinars on various CFD topics. It's a great opportunity to learn about the latest advancements in CFD simulation, see our tools in action first-hand and ask any questions you may have straight to our experts.
Learn how Omnis and Pointwise get you accurate results, faster and at a greatly reduced cost , thanks to dedicated application workflows which cut down on pre-processing and simulation run-time.
Join any one of our upcoming webinars in your field of choice:
 June 15 | VALIDATION OF CFD RESULTS ON A POINTWISE MESH FOR THE POSTDAM MARINE PROPELLER CASE
Learn about validation of CFD results from the TCFD flow solver on a Pointwise mesh for the Potsdam Propeller Test Case (PPTC), a marine propulsor that was extensively measure by SVA Potsdam. The aim of this benchmark was to evaluate the combination of TCFD and Pointwise and to compare the results with experimental data.
 June 22 | HIGHER PERFORMANCE AND LONGER LIFE FOR TURBOMACHINERY THROUGH RETROFITTING OPTIMIZATION
Aging equipment represents a serious challenge for engineers, often requiring retrofitting of entire rows or overhauling of the entire assembly. Learn how CFD simulation can optimize this process, extending rotating machinery life and increasing performance.
 June 23 | BOOST YOUR PRODUCTIVITY WITH THE LATEST VERSION OF OMNIS
A new particle solver, surface-to-volume meshing and more than 100+ new capabilities to boost your productivity in the latest version of Omnis. Witness its power during this webinar with live demos, customer case examples and tips-and-tricks from the experts.
 June 24 | FAST AND RELIABLE CFD SIMULATION OF A PLATE COUNTERFLOW HEAT EXCHANGER
Predicting performance of heat exchangers can be a challenging task. Learn how CFD offers in-depth and accurate analysis of all the flow details early in the design process.
If you are not available on the proposed dates and times, register anyway, we will send you the recording afterwards and you can still send us all your questions through email, we will make sure the experts get back to you with answer.
Plenty of other topics webinars are available for you on-demand HERE
