  3. On-Demand Webinar - Simulating Fluid-Structure Interaction…
AnneMarie S
AnneMarie S
CFD
fluid simulations
featured
fluid-structure interaction
turbomachinery
webinars
Computational Fluid Dynamics
fluid dynamics
Fidelity CFD
Turbo
Cadence CFD
On-Demand Webinar - Simulating Fluid-Structure Interaction (FSI) with Fidelity
1 Aug 2023 • Less than one minute read
On-Demand Webinar: Simulating Fluid-Structure Interaction (FSI) with Fidelity
Register once to get access to all Cadence on-demand webinars.
Fluid-Structure Interaction (FSI) modeling is a fundamental step in the design process of turbomachinery. Highly variable pressure loads and temperature gradients affect not only efficiency and performance but also the structural integrity of blades.
FSI simulations are a challenging activity where mesh deformation techniques, complex modeling, and flow unsteadiness all come into play.
In this TECHTALK, we will introduce the FSI simulation capabilities of the Cadence software, describe how the geometry deformation can be modeled, and how its effect on the fluid field can be understood.
After the TECHTALK, you will know more about:
  • Mesh deformation techniques
  • FSI for steady and unsteady simulations
  • Modeling flutter analysis through the harmonic method
 Watch On-Demand Webinar button  Register once to get access to all Cadence on-demand webinars.
Fluid Structure Interaction CFD Simulation Turbomachinery
