  3. On-Demand Webinar - End-to-end Design and Modeling of Turbo…
AnneMarie S
AnneMarie S
CFD
featured
turbomachinery
webinars
Computational Fluid Dynamics
Cadence Fidelity
fluid dynamics
Fidelity CFD
Turbo
Cadence CFD
On-Demand Webinar - End-to-end Design and Modeling of Turbo Compressors for Hydrogen Applications
12 Jan 2023 • 1 minute read
   Hosted by ASME Mechanical Engineering.
Hydrogen fuel is one of the most promising means to achieve decarbonization and reach the ambitious CO2 reduction goals sought by the energy generation and transportation industries. However, processing, transporting, and storing this gas in the current infrastructure is possible only with adapted and dedicated rotating equipment.
Due to its low molecular weight, hydrogen poses several new challenges: many stages need a substantial pressure ratio, often highly loaded and spinning at a considerably higher speed than air or natural gas turbomachines.
In this webinar, Cadence and our partner Concepts NREC will demonstrate how to use Fidelity Agile to design turbo compressors for hydrogen applications. The Fidelity Agile package offers a complete end-to-end turbomachinery CFD solution, from 1D to 3D, Meshing, CFD, and Optimization, in one single environment. We will briefly cover the energy sector's main challenges, how hydrogen fits as a possible solution, and the role of turbomachinery in the hydrogen infrastructure.
Join us and:
  • Learn how to use Compal and Axcent to easily generate a new hydrogen compressor from scratch within minutes and transfer the geometry seamlessly to Fidelity Flow for CFD analysis.
  • Discover how Fidelity quickly computes the performance map of a multistage compressor, from automatic grid generation to analysis of the results.
  • See examples of how a multistage design can be better understood and analyzed with unsteady simulations.
Reconstruction in time of the pressure and temperature flow field (30 time steps). Only the harmonics in stage 3 are considered.
