  3. On-Demand Webinar - How to Efficiently Mesh Complex Tip…
AnneMarie S
AnneMarie S
CFD
fluid simulations
turbomachinery
webinars
Pointwise
Computational Fluid Dynamics
webinar
fluid dynamics
fidelity
Fidelity CFD
CFD Applications
simulation software
Mesh Generation
Turbo
Cadence CFD
Meshing
Fidelity Pointwise
simulation
On-Demand Webinar - How to Efficiently Mesh Complex Tip Blades with High Accuracy
2 Feb 2023 • 1 minute read
Tip clearance flow is the flow that passes through the small clearance gaps between rotating and stationary components of a turbomachine. The size and shape of such gaps are directly linked to the turbomachine’s aerodynamic performance in terms of efficiency, operating range, vibrations, noise, etc.
Accurately modeling and predicting this flow enables engineers to test many design alternatives and obtain optimal solutions. Computational fluid dynamics (CFD) simulations are crucial for such simulations.
In this on-demand webinar, watch how we mesh a turbine blade with complex tip geometry in the Cadence Fidelity CFD Platform, capturing all its intricate geometric details for both fluid and solid domains. We complete the analysis with a conjugate heat transfer (CHT) simulation using Fidelity CFD’s pressure-based solver that can simultaneously tackle the solution of momentum, continuity, and energy equations.
 Turbomachinery blade tip surface grid with ASM
Blade tip surface grid with ASM
Turbomachinery blade tip CHT vs Adiabatic static temperature
Blade tip CHT vs Adiabatic static temperature
Learn how Fidelity CFD can simulate complex turbomachinery configurations, maintaining high-accuracy flow results and a quick turnaround time for a short engineering product cycle.
