  3. On-Demand Webinar: LMG Marin Cuts Time and Costs in Ship…
AnneMarie S
AnneMarie S
CFD
Marine Engineering
marine design
webinars
marine
fine/marine
Computational Fluid Dynamics
fluid dynamics
CFD Applications
simulation software
On-Demand Webinar: LMG Marin Cuts Time and Costs in Ship Design Using Fine Marine
21 Dec 2022 • 1 minute read
   Register only once to get access to all Cadence on-demand webinars.
LMG Marin is a naval architecture design and engineering office working on commercial ships, such as ferries, tankers, tugs, and catamarans. The role CFD plays in their processes has grown considerably over the years, and it has replaced towing tank tests in most of their designs.
In this webinar, LMG Marin demonstrates how they use Fine Marine at different stages in their design workflow.
Early in the process, when parameters such as CG position, weight, or trim, are not even fully defined yet, they use Fine Marine to obtain preliminary estimations of power, fuel consumption, and propeller size. As LMG has extensive experience and internal procedures in place, they can quickly get accurate data for their design cycles.
They also use Fine Marine throughout the subsequent steps in the project to check resistance and power requirements when constraints are moving. Self-propulsion using actuator disks decreases costs and time spent in a model test basin and checks assumptions made by the propeller supplier.
Finally, they use Fine Marine in Research and Development projects, such as foil development and optimization and seakeeping applications.
Watch now to learn how to cut your costs and time using Fine Marine.
