  3. On-Demand Webinar - Predicting Aerodynamic Flow Around Automotive…
AnneMarie S
AnneMarie S
CFD
Automotive
external aerodynamics
automotive engineering
featured
Computational Fluid Dynamics
fluid dynamics
simulation software
Aerodynamics
On-Demand Webinar - Predicting Aerodynamic Flow Around Automotive Vehicles
19 Oct 2022 • Less than one minute read
Predicting aerodynamic flow physics around automotive vehicles is a complex endeavor, often leaving the engineer with the need to balance cost and accuracy. While steady-state approaches (such as RANS) are attractive for their low computational cost, they usually fail to predict all flow phenomena correctly. More fidelity can be achieved by using unsteady scale-resolving models such as DES or wall-modeled LES, of course at a significantly higher cost.
An ideal model would offer an accurate solution within a small turnaround time, therefore being applicable across the board and allowing for a faster, more consistent, decision making.
Automotive External Aerodynamics CFD Simulation
In this webinar, we present a comparison between standard RANS models, Stress-Omega RSM implementation, and unsteady scale resolving approaches on several representative test cases including Windsor body and DrivAer.
Learning benefits:
  • Demonstration of the full CFD simulation workflow for car external aerodynamics
  • Comparison of speed and accuracy for different turbulence modeling approaches
  • Application to multiple reference car models
