  2. Data Center
  3. Why Sovereign AI Infrastructure Requires Continuous Site…
Veena Parthan
Veena Parthan
CFD
AI infrastructure
data center
Cadence Reality Digital Twin Platform
retrofit
Sovereign AI
Why Sovereign AI Infrastructure Requires Continuous Site Validation
18 Nov 2026 • 2 minute read
Sovereign AI requires AI infrastructure to be developed and operated within defined territorial, legal, security, and operational boundaries. These requirements can limit where data centers are built, who runs them, and where workloads can move—leaving infrastructure teams fewer options to meet performance demands and expand capacity.
Retrofitting adds physical constraints: fixed layouts, pipe routes, limited outdoor space, and existing cooling systems. Equipment may fit without the facility being able to sustain its thermal load. When sovereignty requirements limit alternatives, readiness depends on what the permitted site can reliably support—not simply what can be installed.
A Larsen & Toubro (L&T) study in the eBook Sovereign AI Infrastructure: What to Validate Before You Commit to a Site shows why realistic validation matters. All cabinets in a modeled data hall met the ASHRAE-recommended inlet temperature range under ideal assumptions. With realistic leakage, cooling-control response, and failure conditions, more than half exceeded 27°C in one cooling-failure scenario—even though the design was unchanged.
Figure 1: Peak cabinet inlet temperature in cooling failure mode across four model variations: i) control and leakage, ii) control, no leakage, iii) no control, leakage, iv) no control, no leakage. The facility design is identical in all four runs. Only the modeling assumptions change.
For a sovereign AI deployment facing the same risk, moving workloads elsewhere might not be permitted. In a retrofit, existing infrastructure would further limit the response, potentially requiring cooling modifications or reduced compute capacity. Physics-based simulation helps test these limits before commitment. Recalibrated against measured performance, it supports continuous validation as workloads and infrastructure evolve.
Validate Retrofit Options Within Sovereign AI Constraints
Original drawings are only a baseline; retrofit readiness depends on current site conditions. Sovereign AI facilities must absorb fast-changing compute demands within their installed infrastructure. Validate the full cooling architecture against actual facility geometry and operating conditions before retrofit decisions become costly to reverse.
Assess the Full Cooling Path in the Existing Site
A retrofit’s cooling limits may lie beyond the data hall. Indoor airflow and outdoor heat rejection must work together within the existing site—a connection explored through internal and external CFD in the eBook’s site-validation framework.
Keep Site Assessments Current from Design to Operation
Site validation must evolve with the facility, from design and commissioning to operation and expansion. Keeping physics-based models aligned with measured performance—and testing changes before deployment—are central to the lifecycle validation approach outlined in the eBook.
The Cadence Reality Digital Twin Platform supports this lifecycle approach, connecting design-stage analysis with ongoing assessment of the operating facility.
Build Evidence Before the Next Commitment
When alternatives are limited, a plausible adaptation plan is not enough. A sovereign AI retrofit needs evidence that it can perform under realistic conditions—and a process for keeping that evidence current.
Predictive optimization helped one facility recover 80% of its at-risk IT. Download the eBook to explore how to protect capacity before thermal risks take hold.
