  3. BETA CAE 2026.1 HF1 Software Release Available
Cadence BETA CAE Software
physical systems simulation
SPDRM
KOMVOS
FATIQ
Beta CAE
EPILYSIS
ANSA
Simulation Automation
simulation software
CAE Software
meta
ANSERS
27 Oct 2026 • 7 minute read
About this Release
We officially announce the first hotfix of 2026.1 for ANSA Pre-Processor, EPILYSIS FEA Solver, META Post- Processor, FATIQ Fatigue Analysis Platform, SPDRM Software, KOMVOS SDM Console, and ANSERS Dashboard, with critical bug fixes and selected implementations.
This follows an overview of the most important items:
Known issues resolved in ANSA Pre-Processor
Known issues resolved in META  Post-Processor
Known issues resolved in FATIQ Platform
Known issues resolved in KOMVOS SDM Console
Known issues resolved in SPDRM Software
Known issues resolved in ANSERS Dashboard
Download
Known Issues Resolved in ANSA Pre-Processor
CAD to ANSA Translators
Unexpected termination would occur when translating Rhinoceros files.
GUI
Context menu would not be displayed when pressing the right mouse button in the graphic area and no function was active. The 'Near' function could return inconsistent results when searching around CURVE entities, causing nearby geometry faces or shell mesh that were within the specified search radius to remain hidden. Upon deactivation of the shadow drawing mode, the selection mechanism would fail to consistently pick all elements located behind the visible geometry.
General
ANSA Pre-Processor would terminate abruptly when inputting SEA .xml files containing singly curved faces.
Compare Tool
Opening the "Compare Tool" would cause the tabbed "Models List" to disappear.
Model Browser
ANSA Pre-Processor abortion would take place when editing entity colors from database browser lists.
Middle Meshing
“Create Middle > Sheet metal” function would occasionally produce incomplete middle geometry at tailor-rolled blank parts. Also, middle faces could not be created in areas with variable thickness.
Connections and Assembly
Properties generated during re-application of the spots would be erroneously duplicated, in case their IDs had undergone modifications since the initial realization.
“Create > From FE” function would erroneously take into consideration connection entities already converted to ANSA Pre-Processor connections.
After “Erase FE” of a SPIDER2 connection realized on the “Top Area” of a stamp feature, the elements filling the hole would be added to the “Rest Area” of the stamp feature, causing a subsequent Realize to fail.
Nastran
Empty continuation line would lead to a fatal error when running NASTRAN NX.
Abaqus
The calculation of the resultant force would be incorrect when the resultant force tool was applied to DLOADs with load type Hydrostatic Pressure (HP) and the “Magnitude > Loads” option was deactivated in the presentation parameters.
In addition, “File > Output” execution of a contact marked as auxiliary could lead to an unexpected termination.
LS-DYNA
The context menu “Import > Main File Structure > Create main file include” would lead to unexpected termination when a referenced include used *PARAMETER.
Safety
Abrupt software abortion would occur when ESC was pressed abruptly to terminate seatbelt creation. An unexpected termination would also take place when the seatbelt entities were deleted, and the seatbelt was recreated.
Morphing
ANSA Pre-Processor would exit abnormally when copying PM_features with “steps > 1” via “Create > Symmetry” function execution. In addition, morphing boxes with loaded steady section morphing constraints would fail to perform morphing correctly.
Scripting
The execution of “mesh.VoxelGeneration()” script function would lead to an unexpected termination.
Known Issues Resolved in META Post-Processor
General
META Post-Processor would exit abruptly when double-clicking on the info window. An unexpected termination would also take place when switching profiles. “Auto Fit values” setting, as well as the visibility settings for some drawing styles (hidden, light, deform, fringe, and vector fringe), would not be saved in the defaults. ANSA Pre-Processor comments could not be read from JOINT-type elements.
GUI
Several actions in the Graphical User Interface were not functional anymore when a guitk window was open through drag ‘n’ drop or through the “read session” command.
Read Results
“Read pressure results” from a certain CGNS file could lead to an unexpected termination. FPS files from newer FEMFAT versions wouldn’t be read properly. META Post-Processor would become temporarily suspended when selecting a results file through file path recommendations, using only the keyboard.
Nastran
Fluid particle vector was falsely drawn twice, both in the correct direction and in the opposite direction. Also, curves from .h5 files were read incorrectly.
Abaqus
Abaqus fastener coupling visibility actions were not working properly.
Pam-Crash
Failed elements were not handled correctly when loading FEMZIP ERF file.
Math Operations on Field Data
Regarding strain gauges, calculations with tensor results would not take large translations/rotations into account.
Project Files and METADB
Reading a project file with contribution analysis curves saved with references would result in abrupt software abortion. Script function “results.PrimaryResultsList()” would not return the correct information for METADBs converted from d3plot.
2D Plots
Double-clicking the X-coordinate of a curve point created by bore distortion analysis would lead to META Post-Processor termination. When plotting results from a .res file, the values of the modal coordinates Q of the flexible body would be displayed inaccurately.
Managing Curve Data
Unexpected termination would occur upon creation of 2D Windows when Y-Axis values format was stored in defaults as “Auto-Sci.” Focusing on the template manager, variables used in CSV templates for 2D plot-related entities (plots, axes, curves, etc.) were not evaluated when the template was imported.
Cut Planes
Enabling cut plane editing, while a 2D plot window was in focus, would lead to software abortion. Multiple vector representation functionality would falsely not follow the cut-plane clipping restrictions. Lastly, the applied fringe on cut planes would not be saved properly in METADB.
Annotations
Creating annotations on picked entities from the screen would lead to abnormal termination.
States and Animation
Switching between states could make the results disappear in cases of extremely small time steps.
Images and Video Handling
Scale points for “Plot Tracked Features” could not be picked on the video and on the model.
Report
Unexpected termination would occur after pressing Ctrl+N, following export to JT format. Placing the focus on the laminate report, when saving a property’s HTML laminate report, the report was saved without the associated images in the output folder.
Automation
The script functions “Model.pick_parts”, “Model.pick_elements” and “Model.pick_materias” would falsely return empty lists. Session editor was reporting “Invalid Command” or “Syntax” errors when “utils.MetaCommand()” script function was used in script blocks. Focusing on template manager, when loading a template file with multiple input variables, the recorded session command could not be executed successfully and resulted in the error message “Wrong number of variables.”
Known Issues Resolved in FATIQ Platform
GUI
Modifying a set in a large model could cause a temporary freeze.
Calculations
Focusing on deterministic loads, wrong results were produced when multiple sines were included in a single definition. Furthermore, multiple subcases in deterministic loads were not handled properly. Speaking of modal response, changes to the duty cycle event duration were occasionally not handled correctly.
Post-Processing
Element and node information was not included in the time series output of Multiaxial analysis. Also, an incorrect transfer function was used in case of having multiple subcases in deterministic loads.
Known Issues Resolved in KOMVOS SDM Console
GUI
The KOMVOS profile name would not be updated in the main panel upon reconnecting to SPDRM.
Model Building Tools – CAD to CAE
3dxml files as part representation files would fail to be displayed in the Viewer of the “CAD to CAE” workspace.
In addition, part build orchestrator would not identify carry-over fasteners.
Data Management
Built-in imports through KOMVOS could violate LBR.
Also, adding and removing an Attached_to_main file through the properties card would not operate properly.
Known Issues Resolved in SPDRM Software
Data Management
When the exported file structure was enabled for fasteners (FEATURE_ITEMS), the associated representation files (.ANSA) were not synchronized to the file system.
Process Library
A new workflow has been added to assist the context-aware part classifier creation from ANSA. The workflow is bound with the respective ANSA function and allows the asynchronous training and saving of the context-aware part classifier predictor.
Script API
Extended the SPDRM script API with the new functions dm.archiveDMObjectsByQuery and dm.deleteDMObjectsByQuery, enabling data objects to be archived or deleted based on BetaQL query criteria. This enhancement allows scheduled scripts to automate data lifecycle management tasks directly through the script API, simplifying the implementation of periodic cleanup and archiving processes that were previously available only through the REST API.
System Configuration
Enhanced the server-side configuration to support remote site assignment using IP ranges defined in CIDR notation (e.g., 10.45.0.0/18). This improvement enables system administrators to define site-specific IP ranges more efficiently, reducing configuration complexity and improving maintainability.
Known Issues Resolved in ANSERS Dashboard
Datasources
Filesystem methods parses XLSX/CSV files would not operate properly when a transformer with multiple file objects was set in fieldfileUrl.
Dashlets
Selected files would not be imported together in a single action. The import functionality for dashlets and library items has now been enhanced to support multiple JSON file selection.
Download
Where to Download From
You can find this release on Cadence Downloads, dated as of October 27, 2026. Customers who are served by a local business agent should contact the local support channel for software distribution details.
