  3. BETA CAE Team Announces v25.1 HF6 Software Release
Cadence BETA CAE Software
physical systems simulation
KOMVOS
computer-aided engineering
Beta CAE
ANSA
simulation software
CAE
BetaCAE
CAE Software
meta
8 Oct 2026 • 2 minute read
About this Release
We officially announce the last bug-fix release of the v25.1.x series for ANSA Advanced CAE Pre-Processor, EPILYSIS FEA Solver, META Post-Processor, and KOMVOS SDM Console, with critical bug fixes.
Follows an overview of the most important items:
Known Issues Resolved in ANSA
Known Issues Resolved in META
Known Issues Resolved in KOMVOS
Download
GUI
Unexpected termination would occur when using the "[STRIKEOUT:>" syntax to get the id of a material used in a material reference field in a PART_COMPOSITE property list (i.e. MID1]>MID).
Focusing on visibility, the "Near" function could return inconsistent results when searching around CURVE entities, causing nearby geometry faces or shell mesh that were within the specified search radius to remain hidden.
Model Browser
Abrupt software abortion would take place when editing entity color from Database Browser lists.
Middle Meshing
Middle faces would occasionally not be created in areas with variable thickness.
Connections & Assembly
After executing "Erase FE" of a SPIDER2 connection realized on the "Top Area" of a stamp feature, the elements filling the hole would be added to the "Rest Area" of the stamp feature, causing a subsequent Realize action to fail.
NX Nastran
Empty continuation line upon output would lead to Fatal Error when running NX Nastran.
Abaqus
Under Clearance Tabular Data, Calculation of Bolt Axis provided by Set, was not performed properly.
LS-DYNA
During creation of "DEFORMABLE_TO_RIGID: Rigid: PART", it was not possible to select a part.
Box Morphing
Boxes with loaded Steady Section Morphing Constraints, would fail to perform morphing correctly.
Optistruct
During output, ANSA would falsely write blank stiffness (K) values in the produced *.fem file for PBUSH properties, leading to errors during FE Analysis.
Abaqus
Assembly set loading would be incorrect for *.odb files containing instances.
LS-DYNA
Results on transformed Includes were not displayed correctly on the corresponding transformed geometry.
Read Results
When loading a curve from a column ASCII format file using the "Bar Plot from Column" or "Bar Plot from Row" format options on 2D plots, when plotting results from a *.res file, the values of the modal coordinates Q of the flexible body could be displayed significantly higher than expected.
Managing Curve Data
META would terminate unexpectedly in cases of binout files with rbdout section.
Report
Focusing on Spreadsheet Editor, extending LOG10 function to several cells led to corruption of the function. The same corrupted behavior was noticed while loading XLSX spreadsheet with extended LOG10 formulas.
Configuration - GUI
SPDRM action applied in ANSA would not be available in the context menu of parts, although it was configured properly in the dm_profiles.xml.
Download
Where to Download From
You can find this release on Cadence Downloads, dated as of September 22, 2026.
Customers who are served by a local business agent should contact the local support channel for software distribution details.
